J-Spec Tuner wrote:and parts dont wear out on the KA?
very not true, at least 90% of the people i know running SRs are using the stock bottom end that came with the motor. Phase2motortrend is past the 500rwhp mark on the STOCK bottom end of a junk motor they got from japan. The SR will be more reliable and make more power than a KA-T without a rebuild.
I'm not talking about bottom ends. Im talking about radiators, coolant hoses, vacuum hoses, oil pans, oil pumps, injectors, fuel pumps, turbos, turbo oil lines, etc. All of these things will be added brand new when you do a KA-T, along with a rebuilt head (cams, springs, porting, etc.) and bottom end (stock rods, stock pistons, stock crank.) for any motor over 50k miles. If you go wtih an SR you have to replace all these things eventually (like you are Jspec in rebuilding)
I am also not talking about 500 rwhp, that is much more than 10 grand. I'm talking about 250 rwhp, MAX.
