Project el cheapo KA-T - * FRESHLY UPDATED WITH INTERNAL ENGINE PICS *
WDRacing
That pic makes it look like it came from the factory boosted. Well done Aaron.
Chezedik wrote:Are you sure that's an FMU and not a FPR?
Agreed, that looks like a AFPR not a FMU. Are we high?
WD
Chezedik
Car: 1991 Nissan 240sx
I don't know about you but a I have a Vault Zero here.
There do make adjustable FMU's but aren't all FMUs round, since they require the discs?
Bwana
Car: Denali
WDRacing wrote:That pic makes it look like it came from the factory boosted. Well done Aaron. WD
Wait till you see the completed down pipe, it will dispel all such illusions...
I'm not absolutely sure. That's what he told me, but it has no identifying markings on it, so???
jmwenick
Car: 1991 240sx Base Model
Just up the pressure to like 60PSI or something, should get a few more cc's of fuel in there. Just make sure the fuel lines are on good.
WDRacing
Then he gets crap gas mileage and his idle AFR's go in the gutter...
I'm trying to get him to swap in some 370's he has and go with a MAF Bypass and base timing retard for tuning.
WD
Abdo
Car: S13 RB25DET
Bwana wrote: I'm not absolutely sure. That's what he told me, but it has no identifying markings on it, so???
-yea im almost positive thats a fuel pressure regulator
good job on ghetto rigging a sohc ka-t! fkin sweetness, props on your custom work
sil80drifter
Car: 1990 240SX Hatch
OMG
Please remove valve cover tube from cold pipe unless you plan on boosting the crap out of the valvetrain and block insides.....
Although funny to an onlooker it would surely make your entire budget and craftsmanship efforts moot.
Yeah, WD sorry, I'll buy you a beer if you're ever in CT.
sil80
Modified by sil80drifter at 1:35 PM 4/1/2007
jmwenick
WDRacing wrote:Then he gets crap gas mileage and his idle AFR's go in the gutter...
WD
Not true, My Enthalpy ecu I have been running at 75psi and Have perfect idle and cruise. I just don't know if it is safe. But in his situation, it might not matter, cause he has the RB waiting.
AA, that thing RULES.
Looks like something I flushed after a night of Coronas and Taco Bell, but it's cool.
Chingon
Car: 1991 and 1992 hatchbacks
Chezedik wrote:Bet the first problem is that the pipe dope fails. Not naysaying, but I know that stuff. I built a boost leak detector and it kept popping off. But you might be alright at only 7psi.
I've seen pvc hydrotested to 90 psi w/o problems..
WDRacing
If you're running 75psi its because the tune sucks or you would be running rich, don't argue because thats fact. Rom tunes are either designed for high fuel pressure or they are designed around a 43.5 psi base fuel pressure. Increasing said fuel pressure WILL make the fuel map rich...period.
Chezedik
Is that the Tim Armstrong Project?
EDIT: only if that is him in the background.
Bwana
Car: Denali
Chezedik wrote:Is that the Tim Armstrong Project?
No idea lol. It's some random pic Dano sent me to replace Brian's (assumed) edit.
Chezedik
Beats the hell out of the tulips I get.
Bwana
Car: Denali
Update #2 - Project Success!
After a couple minor issues, the project has been deemed a success! The issues basically consisted of me neglecting to disconnect one of the pcv lines resulting in poor oil drainage characteristics in the turbo drain (think m4d smoking turbo) as well as some oil loss in other places. With that rectified everything seems to be pretty satisfactory. I didn't really have room for the wastegate actuator, so we just wired it shut. We're making max boost of 8 psi at approx 2700-2900 rpm. Here's some pics of everything.
Our sweet temp boost gauge
Apex-i GT exhaust (it came with the RB, so I figured I might as well put it on, it sounds great!).
The FMIC that also came with the RB.
Plumbing, cold pipe side.
REAL FMU installed in there.
Ign coil relocated to former air box location.
Side view of the turbo, showing the drain, supply etc.
The sweet downpipe mentioned before, kinda brutal but no leaks!
And finally, an over-all front view of the turbo.
That's really all there is to it. It took me about a week, working a few evenings and one Saturday. I'll be doing a realistic market value breakdown on everything shortly.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Taken it for a spin yet?
nvrplzd240
Car: 04 G35, 02 CBR600 f4i, 90 Sentra
WOW bro
She looks great..
Bwana
Car: Denali
redtop91 wrote:Taken it for a spin yet?
You bet, flogged the heck out of it too.
Chezedik
Good Deal. How does it feel?
Florida240sx
Get to the track before she blows. or dyno. SOHC-T FTW
redtop91
You sir are THE manly men of men.
Dieselman
Car: 07 Ram 3500 Cummins Diesel.
Yessir! I drove it a bit also. 5500-6000 rpm and bangin the gears
If I had to guess it picked up close to 50hp
redtop91
LOL 90->140 whp?
Bwana
Car: Denali
redtop91 wrote:LOL 90->140 whp?
It's no rocket, but a 50-60% hp gain for $2-300 isn't bad.
redtop91
Indeedie. There is a SOHC down the street that you have inspired my to buy.
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
i must give congrats, cheap custom turbo in under a week, sick.
Abdo
Car: S13 RB25DET
badass dude, post some vids of that beast
i cant wait for ur rb25
sil80drifter
OMG!I was right!You had issue with the valve cover being boosted! Glad you got it all set, sounds like a very fun setup!
sil80
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
thats awesome that its succesful! Vids or Ban!
Chezedik
Def, we need vids!
