float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Apr 14, 2004 2:41 pm
There IS reasoning behind increasing the compression. Ok, so here is the deal;
When turboing a motor, most people lower the compression so that you can run more boost. But the problem is that you sacrifice your bottom end when you do that. Kinda like putting a great big turbo and lumpy cams in a car. It's great in the top end, but doesn't have a nice powerband. It's too peaky. BUT if you aren't nessiccarily looking for max power, and you want a broad powerband, you can run less boost, but raise the compression so that in the lower end you've got the compression to give you power before the turbo spools, and then the turbo will carry you the rest of the way through. The problem is that it puts a lot of stress on the head, gasket, piston, rods, bearings, and crank. I still intend to build I high compression CA motor to autocross with, but I'm going to learn from Sean's mistake and wait to put in forged high comp piston's and some sort of standalone engine management so that I can have better control of the timing. We're all (Or should be) aware of the CA's dislike for advanced timing. Unfortunatly, retarding the static timing only makes the motor safer. When you retard it for the top end, you loose out in the bottom end, which negates the whole purpose of building a high comp turbo motor anyway. Ideally you would want to set up your timing curves so that your timing would be well advanced before the turbo spooled, and then as it spooled up, the timing would retard.
Sean, I feel for ya man. But don't give up on us. One of us will conquer the high comp CA yet, just watch! Keep us updated.
