Project: All-out!!!!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Looking hoss. I require a screamer pipe vented out the hood.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
kapower06 wrote:
are those stock rods on the box back there, if so can you email some closeup pictures to [email protected], theres something i want to see about them that i cant see by just popping off my oil pan
phil
mdubc405
Car: white 1989 240sx coupe w/ca18det(t3/t4 .50trim)
nice girlfriend...oh and the motor is ok too... haha
kapower06
once again thanks guys. I am very lucky!
r34-gtr I will have a screamer pipe most likely dumped under the car, poissibly with a muffler from a 2-stroke dirt bike that I have laying around (just to see what it sounds like)
meangreen- lemme know where you need the pictures. Those rods are for sale if your interested! $225 shipped.
UPDATE!!!!I just got done ordering my manifold (ssac) and my gt 4-bolt----to--- 3" v-band" a set of 3" v-bands, oil inlet fitting, (3) 14mm banjo bolts with 3/8" barb fittings for coolant feed and return, along with the turbine inlet and outlet gaskets. Next week I'll order my wastegate, then whenever I receive my cams I can finish her up. I'll keep everyone posted
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
Looking good.
Good to see you using gloves in the garage, the missus is worth it. Otherwise I'd call you names for avoiding getting your hands dirty. :-)
MeanGreenS13
[email protected] i stated above. I dont need ot buy any, my motor seems to be an EXTREMELY low mileage engine for a CA due to how the main bearings looked, im just not going to pull the entire thing apart... yet, i just want to look at the rods as well as i can before i decide if ill ever need pauter or not
kapower06
Ok guys I finally got some updated pics fo yall!!!!
And for my favorite!!!
And thats all the pictures I have so far. But i've got the water and oil lines ready to go on, Got all the coolant and vacuum lines ready, Also have the water pump bolted on, the t-stat housing, and the hall sensor bracket mounted along with the alternator.
I've also ordered my wastegate last thursday, so it should be here middle of this coming week. At the point I will drop the engine in with everything bolted up and ready to go besides the cams, Which Im also expecting by the end of next week. Soo if all goes as planed, I should be able to get it going hopefully by the following weekend if not the next. Woo-HOO!!!
I promise that I will hit the dyno by half way through November, which gives me time to get things straightened out (downpipe, hot/cold pipes/ tuning and break-in)
g-ride
Car: 1991 Nissan 240sx
Wow, that thing is gay. If you ever get that out of the basement maybe one of my cars will get boosted. Ricer
I'll give you your first race against a bike
Oh yea... I'm his older brother. My girlfriend has huge boobs
TD or Not TD
Car: 1986 Corolla GTS
pics pls
turbo-sil40
Car: 00' Land Rover Discovery, 1990 nissan silvia conversion coupe with CA turbo swap
I had the same manifold on my car with a TO4E turbo and the center of the turbo rubbed on the bottom of the brake master cylinder and caused the fluid to boil so you should check it out first before you get the whole setup in
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
great build, hot g/f. big grin u must have priceless
ilovecoupes
TD or Not TD wrote:
pics pls
agreedless pictures of motors and turbosmore pictues of people's girlfriends.
sick build. I can't wait to see numbers!
g-ride
im not jacking my lil bro's thread with my gfs boobs.. just think 34-F
r34 gtr
Ok, now I NEED pictures. Or I will come into your house at night and smother you... in gravy.
float_6969
That's not the scary part. The scary part is that he licks it off afterwards.
kapower06
UPDATE!!!!
Put the engine in to make sure everything will clear before I tighten everything down....... and
The turbine is about an 1/8th inch away from the BMC/fender. And the waste gate is about a half inch from the fender..... FU*K! It clears but its too tight for me. So im going to make my own manifold. Prolly gunna mount the turbo up by the front of the engine, kinda by the dipstick tube area, that way I can have plenty of room for a downpipe and the oil/water lines. I'll up-date pictures as I go. As for now Im just going to cut the flanges off of the SSAC manifold and go from there. Then get a couple of 90* and 45* 1-1/2" butt-welds. .... Or I can just chop off the turbo flange and mount it about an inch closer to the engine and all will be gravy but I dunno.
good morning
All that money and you are going to run SDS?
Spend a little more money and get AEM.
zero_gripS13
Car: soon to be 95 s14 hopefully
hell yea man keep it up..great work your doing..i cant wait to see the results..
deffinetley inspiring to get my build going.
nvrplzd240
Car: 04 G35, 02 CBR600 f4i, 90 Sentra
Sick build so far bro.
Sorry I haven't chimed in sooner.
Looks like she'll be siiiiiick once you finally get her all set. And although I didn't go through the the same steps as you, mine was still down for freaking forever due to unplanned issues... but the wait is worth it lol.
kapower06
after much research and testimonials about both systems, I think the SDS suits my needs better. I also dislike the stock CAS and COP design. Also Its quiet a bit $500+/- more for the AEM, then the UEGO, and a laptop which I dont have, Also most of the wires in the factory harness were getting old,brittle and corroded. If I feel that the SDS is not sufficient enough(which I feel it is very sufficient for anything that I will ever throw at it)
zero_gripS13..... Thanks man, Im doig my best to get her going. Im waiting for a return email regarding a manifold, If that doesn't go through then I will be building my own t3 top mount. All I am waiting on is my cams to come in. Which should be very soon, hopefullly. Then I will get her up and runnng within a week or so.
UGH!!!!!!!!!!! I can't wait
zero_gripS13
r
kapower06 wrote:after much research and testimonials about both systems, I think the SDS suits my needs better. I also dislike the stock CAS and COP design. Also Its quiet a bit $500+/- more for the AEM, then the UEGO, and a laptop which I dont have, Also most of the wires in the factory harness were getting old,brittle and corroded. If I feel that the SDS is not sufficient enough(which I feel it is very sufficient for anything that I will ever throw at it)
a
really awesome... you have to get some vids i wanna hear that bad boy ...
good morning
AEM is configable to most postion sensors. It also has boost control, so that $300-400 you are spending on a boost control you could use to the box. Aem also has ALOT more features.
AEM also has internal and true datlogging , not some small screen. You still have to buy a wideband for either.
