yea thats another thing i am doing it this way cause money is of the essence and is not available at full amounts you know so maybe this will help those guys that have a income coming in and be able to boost their car in a shorter time framebeancooker wrote:AWESOME!!! Glad to see that you chose to make your own path. It looks like an awesome project. Please keep us updated. There are a few other Maxima owners that want to boost, but do not know exactly what to do, or how much it should cost.
Once again... AWESOME!
Ok to start off on what you suggested. Yea its going ot be a crossover pipe and thank you for reminding me about the flex pipe since the motor does move while driving and startup and due to the head it expands i am grateful for reminding me about that.mtcookson wrote:Looks good so far. Some things I'd like to point out looking at the pictures...
If possible, can you run the turbo to the piping that runs to the passenger's side? If so, this will take away that high angle coupler and help out a efficiency a little bit. In this picture below, the pipe connected to the intake, I'd run two 90 degree couplers or tubes to the turbo instead and the pipe that originally would be going to the turbo would go to the intake. This will smooth out the bends overall and should help overall efficiency, especially since the piping going from the aftercooler to the intake would not be running across the engine bay behind the radiator and above the manifolds. Basically, the pipe will see less heat and the bends should be smoother overall. Should help out efficiency a little bit. (hopefully that wasn't too confusing )On the exhaust manifolds, from what I understand you're making a crossover pipe for the turbo to bolt on, which I think is an excellent idea. That's how I setup my 3rd gen Maxima turbo setup. One very important thing to have on the crossover pipe is a flex pipe. This will keep manifold studs and such from breaking due to the expansion and contraction of the manifolds.
Other than that, looks good and I definitely would like to see how it runs. Good luck!
ok yeah what i was thinking but leaving the turbo in the same place and switching side of the piping pretty much driver side to TB and passenger side IC piping to turbo......ok i got you know yeah ima have to switch the turbo around having the exhaust side int he front and the intake side int he back and making a ubend pipe for the intake to stick the filter right where the CAI goesmtcookson wrote:Actually, you would just leave the turbo as it is. I did the same thing having the compressor side on the back and turbine on the front so that the exhaust would come forward and down. Here's how I would do your setup (crappy picture, but hopefully it shows it ok):
now that you bring up the hood scoop i had that discussion the other day with my boy and my tech. have the scoop and the airfilter right there like the STI's pretty much ram air. i been thinking about it a lot to.......but as a safe measure or cheaper measure for now i prlly can get it to sit where it used to sit as a CAI see the whole hood scoop worries me for when it rains down here in miami it pours so i dunnomtcookson wrote:Yeah, the intake pipe is the only difficult part. One third gen guy did the u-bend to the inner fender CAI style. I temporarily had mine just run behind the engine as I was undecided on how to do it. I was thinking of doing a hood scoop and a few other ideas but haven't really decided yet.
thats what i was thinking about right now but in a way i can kinda slant the turbo sideways not sideays all the way but at a small enough angle that the intake piping only needs a 45 degree pipe instead of a u-bend what do you think about thatmtcookson wrote:Yeah, rain was definitely a concern. I had an idea wrote down on my laptop of how to get around it but I can't remember it off hand and my laptop is dead at the moment.
The u-bend won't be the most efficient but would definitely work for the time being.
oh yea wow rust issues r more important. I think a nice 30 or 45 would be a good enough angle to where we dont need the u bend ima mock up the turbo and see if a 45 degree pipe will work fine and I will post up the pic for you later to see if our theories will work. its all trial and error when it comes to projects like this. I appreciate alot your input. trust me your piping idea has helped alot more than you think out of the 6 people including you that have seen my setup in person and you on here you are the only one to have mentioned that I thank you alotmtcookson wrote:That is another idea I had. The crossover pipe I had setup wouldn't allow me to do that but that is definitely something I was considering and should work really well.
I had another idea of actually bringing the turbo out even more pointing the inlet directly to the driver's side and the exhaust outlet to the passenger's side. The only downside I could see with that is with my manifold setup it made for a 180 degree shift for the front manifold. I was going to modify it to only have a 90 degree bend but started finding some major rust issues and directed my attention to that.
well tomorrow im definitely try this out and see whats up with it so i will let you know ok and post up the picsmtcookson wrote:Not a problem at all. I think the 45 should work out really well but the pictures will definitely make it easier to figure out.
Nice work man ... like you said we all cant keep on doing the same thing we have to rase the bar for the maxima thats why i did what i did ....here is a link to my car ....i got the same thing you got nothing but smart *** people telling it couldnt work but i didnt listen to them because while thye were telling me this and that i was doing the swap ..... Anyway dont mean to whore your thread just great to see guyz like us dont let othere people hold us back from doing something diffrent.... good luck on the project. Here's my thread, WD Rocks for fixing my link. i dont know why it wouldn't post as a link but u can copy and past if you want.95prmax wrote:
Now secondly to the way the turbo is positioned and where in the engine bay. You have raised a very interesting situation for me. Since i read this reply earlier i have been thinking a lot about it. For one when i had started out i wanted to setup the turbo over the transmission and run the exhaust down and back found out that couldnt be done due to the axles and what not. Then i had decided to just flip the turbo and have the exhaust coming forward and then down to the back underneath.
Now that you brought this up i agree with you to many pipes and bends in places that have heat constantly. now just so you know four fans are attached to the radiator and thats four racing fans. Anyways as for the turbo position and placement. I agree i have been pondering this all day if i place the turbo where the Windshield wiper fluid reservoir goes i can easily connect that intercooler pipe to the turbo and the other one coming out of the CAI hole straight into the TB.
My question is this. Since my turbo now would be on the passenger side in that spot i would now have to do the crossover pipe of the two exhaust manifolds and have a piping coming out of the crossover section and around between the headers and the radiator all the way til that section where the turbo is with the T4 flange. Am i correct on that or how did you do it on your 3rd gen if i may ask.
Once again guys i appreciate this alot
Hey thanks man i greatly appreciate it hey where can i get one of those jackets lol.......scooponboost wrote:Nice work man ... like you said we all cant keep on doing the same thing we have to rase the bar for the maxima thats why i did what i did ....here is a link to my car ....i got the same thing you got nothing but smart *** people telling it couldnt work but i didnt listen to them because while thye were telling me this and that i was doing the swap ..... Anyway dont mean to whore your thread just great to see guyz like us dont let othere people hold us back from doing something diffrent.... good luck on the project....... .http://forums.maxima.org/showthread.php?t=518684 ..... i dont know why it would post as alink but u can coy and past if you want
ok yea the intercooler will fit but you loose your foglights for sure if you had any to begin with. Also you gotta trim down the bumper a whole lot.....i mean a lot hell and justa piece of advise. DO NOT I REPEAT DO NOT use a box cutter to trim it cause the bumper is really easy to cut with a box cutter and it just slides thru but this is what happenes whent he box cutter slides through the bumper like if it was butter:A.Tech wrote:Wow. This is utter SIckness. I can't wait to see it all done... Please put up Dyno specs if u can...
Also... I did not know an IC that big would fit so nicely with the bumper... Any modding to get that sucker in?
Hey maybe ill line one up for ya ...lol we are a crew based oout of NY but we got one or 2 members down there in FL.....We are going to be down there this summer maybe we can see how that car is running by that time lol.....Good luck .. ill keep intouch95prmax wrote:
anyways yea man i dont find it any fun to do the same crap everyone else is doing. If my car wont idle right or whatever when i go to start it up its jus tmore interesting thats why its a project you are always gonna have issues. Just like when they started to do the VQ35DE swaps. issues but hey....we need to keep breaking through the wall that keeps getting put in front of us to make maximas come out tot he world and see that the VQ power is no joke
Oh for sure more than welcome to visit my house and check it out when you come down here. By the wyay do you know when you are coming down and for how long. If anything we can also do some Miami partying lolscooponboost wrote:
Sounds like a plane....i dont have exact dates but i know that i will be staying down there for atleast a week so that partying sounds like a good idea .. Maybe we can hit the GOLDEN NUGGET..we got to keep in touch.....MIaimi full of boosted maximas ..omg what is this world comeing to95prmax wrote:
The golden nugget is nothing dont worry about that place forget about that i know better sites for that. there are a couple of boosted maximas down here. question are you driving down or flyingscooponboost wrote:Sounds like a plane....i dont have exact dates but i know that i will be staying down there for atleast a week so that partying sounds like a good idea .. Maybe we can hit the GOLDEN NUGGET..we got to keep in touch.....MIaimi full of boosted maximas ..omg what is this world comeing to
We are driveing there is no fun in flying... thats what im talking about if you know better spots then the nugget and the nugget is the **** im down.... we def going to link up when i touch down there for sho.. anyway more important how is the project comeing along?95prmax wrote:
