Jesda did u use the graphite powder ??Jesda wrote:1) Use a tube of graphite (available at Home Depot) to spray into the key hole and on the key to lubricate it. That did the trick for me and it improved over time with use. If that fails...
2) Have a brand new key made based on your VIN number. Should be $50-$100. And then...
3) Have the ignition lock cylinder professionally readjusted/rebuilt based on the brand new key. Should be $50-$100.
Lol looked like he did!jamesmost wrote:Jesda did u use the graphite powder ??
I have done (1) and (2) already - the new factory key cost $142 plus tax from my friendly but inflated priced Infiniti dealer. The factory key is much better, it works about 1 out of 3 times! I'm going to do (3) - in California your $50-$100 is at least $200.Jesda wrote:1) Use a tube of graphite (available at Home Depot) to spray into the key hole and on the key to lubricate it. That did the trick for me and it improved over time with use. If that fails...
I was really hoping that this was fixed in the 94s and newer. Hopefully the rebuild isn't painfull (i.e. resonable price and it works!)jamesmost wrote:my 95 is starting to do that as well
Ahh, the double wafer tumbler: bane of lock-picks everywhere!Q451990 wrote:This type of lock is commonly called a "wafer lock" by locksmiths.Heath
hmmmm... the price is sure right. But I don't see how that makes a difference. Does the ring somehow keep the cylinder aligned? Looser seems like it would be worse, not better. I'm going to take it apart and see. ThanksQ45denver wrote:I had the same problem with my 1990-even with the replacement factory key. I finally just removed the clear. plastic ring around the outside of the lock and now it works fine with either key.
Other posts claim aftermarket keys degrade the cylinder.I have origional wife has aftermarket. origional used 90% of the timedannymchale wrote:I seem to recall from my memory that the original Infiniti keys are made from Platnium and appear to wear the locks down faster.
My Q didn't come with the original key and I was going to have one made that's how all this came up. I just use a aftermarket key cut from a good locksmith.
If you think about it, Inifiniti even stopped using those keys.
They look really really cool, but over the long haul 150k cause problems I hear.
Damn Qship, does this mean I have to get this off my keychain?qship96 wrote:and.................dont put lots of keys,doo-dads,heavy keychain ornaments on your keyring,as the added grams will accelerate wear to lock and key.
I am experiencing the same problem with my car right now. It's real frustrating. I called Joe and he recommended calling a locksmith and also mentioned that he's not allowed to sell a new key to an out-of-state cutomer. I'm going to start calling around to see how much rebuilding a lock cylinder will cost.JedCoop wrote:My '92Q has over 190K. I have the original two factory keys. Both of which progressively have gotten worse and worse. They get stuck during insertion into the iginition key slot, now it takes five or so minutes to get the right magic combination to get the key inserted. ...so I bought a new factory key from Infiniti to solve the problem...$150 later, the new key works usually in the first five attempts, so it takes only 20 seconds or so to start the car - a real improvement , but it still stinks. The key gets stuck just when the small square hole in the key is about to go into the key cylinder.
