IanS »
https://forums.nicoclub.com/ians-u23642.html
Sun Apr 29, 2007 8:10 am
well, my clutch is slipping, I cant dump it into second or third gear without it slipping, its an RPS stage 2, 6 puck with turbo pressure plate, Ive got about 10,000 miles on, and it was properly broken in. Ever since I installed the clutch Ive been having a problem with the clutch dragging even when the clutch is in, like if I pull up to traffic, put it in first and let the clutch out, but then have to put the clutch back in, it wont disengage from gear until I step on the brake or yank it out of first. Now at first I thought it was the hydrolic system, Ive got a new slave, and the damper box is removed, Im also running DOT 5 fluid. Ive spoken with RPS about this and they seem to think that it is most likely a bent clutch puck, causing the clutch disc to bind on the input shaft and not letting it release from the flywheel, this in turn will cause premature failure. Id like to know if anyone else has ever had this problem. Luckily the guys at RPS are willing to warranty it
sorry for the long post
