problems with D2 coilovers thread
publicenemy137
Car: cars, cars, and cars
^ definetly indecisive, I don't know as much as I'd like to about these coilovers, having last second doubts, but in the end i'm goin to buy em.
publicenemy137
going to place my order tomorrow *fingers crossed*
j-z
Car: 95 240sx
publicenemy137 wrote:I plan to just set my springs for good performance and handling but still a soft ride, for daily driving. I'm not goin to drift or do corners at 40 mph. I just want something to lower my car to make it look better, handle better, and have a softer ride.
then get $150 lowering springs if thats all you want. why spend extra money when what youre gonna buy you wont even use?
SmithSR
Car: 240sx
^^good point!
We've already been over this! If you want a softer ride, you need to look into some luxury brand cars. If you want a lower ride height, don't plan on adjusting suspension, want to make it look better, handle better, etc.... get lowering springs and call it done.
Phil :)
j-z
Car: 95 240sx
phil, i agree with every logical thing youre saying. these coilovers are in no way close to being as soft as stock. if anyone says theyre not that bad theyre lying. i have the 7/5 setup and there no where near to being as soft as stock. even with the 5/3.5 setup will still be stiff as ****. i dont mind the stiffness. i knew thats what these coilovers would bring. thats why i bought them, to have a much stiffer ride for better handling because everntually when i get settled with funds i will be hitting up parking lots and road courses on the weekend. if all you want is a nice looking stance then just get lowering springs. these coilovers are made to perform, not to ride around on the street with (even though you can, but thats now what theyre made for).
Stuntman240
Car: 91 coupe
as far as spring rates i have the whiteline springs and i just wanted to know what #/# my springs are or what they may be comprable to. i just know the in/lb rate: Front 157 lbs/in (linear) & Rear 132-205 lbs/in (progressive). are these too soft???
publicenemy137
well lowering springs you have to buy shocks also, those would cost around $600 and are not adjustable. And screw softness, I'm goin for handling.
publicenemy137
Hey do these last long? j-z said they aren't made for daily driving, I'm probably goin to drive it everyday, how long can I expect these to last???
crzycav86
Car: 93 Nissan 240SX KAT
Actually, you can get kyb agx adjustable shocks for less than $400.
The coilovers come with a tag saying "for track use only". But someone in japan had them on his integra for one or two years, and they haven't gone bad. Those are japanese roads though.
Nismo_Freak
Car: 89 Nissan 240SX
Stuntman240 wrote:as far as spring rates i have the whiteline springs and i just wanted to know what #/# my springs are or what they may be comprable to. i just know the in/lb rate: Front 157 lbs/in (linear) & Rear 132-205 lbs/in (progressive). are these too soft???
157 lbs/in = 2.80 kgf/mm132 lbs/in = 2.36 kgf/mm205 lbs/in = 3.66 kgf/mm
The rear rate is progressive to counteract the cars factory understeer situation in hard cornering.
Nismo_Freak
publicenemy137 wrote:And screw softness, I'm goin for handling.
Hard springs doesn't equal handling ability. Especially on the street.
My car could outhandle a Formula 1 car on a bumpy road simply because while he is skating along, my suspension still has adequate dampening to absorb road irregularites.
If you want handling ability I'd suggest better tires before suspension.
You should make more sacrifice in tires than suspension.
jdmfreak
And I believe the KYB AGXs are agustable too.
nokuntrol
I've got D2 coilovers for my S14 and the rears really are too low. what's the solution?
