SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sat Apr 17, 2004 5:13 pm
To get a softer than stock ride, you'd need lower spring rates, and less damping force, paired to anti-sway bars with less roll stiffness. Do you want any of those things?
There is no magical setting that will lessen the effects of a shorter spring with a higher spring rate. Sorry. You can set a shock dial to it's lowest possible rate, and still have a bone-jarring spring to contend with. Ever see a Honda civic bounce down the road? We all have. Chances are, it's a combination of too stiff or cut springs paired with junk struts or blown struts or struts that are bottoming out.
The common perception of better handling, is a firmer-than-stock ride which tends to respond to driver input quicker. Q45tech would tell you that a significantly better tire would yield a better return, if you were to do instrumented testing for roadholding and cornering.
Since nobody here will do instrumented testing, but would rather plop down big bucks for a coilover package with near unlimited adjustability range, and call it an improvement, I call it hype. You don't have to believe me, but you should at least go back and search through some of Q45tech's old posts to see what he says about increase in lateral road holding when comparing stiffer springs, to stiffer roll bars, to tire upgrades. What I've taken from his posts are, greater gains in actual road holding and actual performance can be found in matching roll stiffness to your tires. Over-stiff suspension produces lower road holding. Some body roll is intended and actually a plus.
So, back to your question of if there is a setting that rides softer than stock and handle better. Those are obviously two subjective qualities, and since, again, nobody here will do instrumented testing, nobody can actually prove either is true, except by what the seat of their pants tells them. Sounds like a story from a mechanic under the shade tree.
Bottom line is, you're asking for a strut assy to do two opposite things. People may tell you that it's possible, but that is their perception of what the ride "used to be" compared to what the ride "is now" and that can be conjecture, bar-stool racing, shade tree war stories.... take it for what it's worth, because only instrumented testing would disprove me, or prove others to be correct.
