robomatic12 wrote:While the engine is warming up, having a higher idle... I cannot hear any misfire. It's only apparently when fully warmed up and the idle has dropped down.
I've done a little bit of searching around on twinturbo.net and there are some posts saying that due to the lowered spark gap at 0.035 instead of 0.044 stock there is a normal odd pop noise at idle. Apparently normal unless the engine is shaking? Does this make sense?
Figure at idle the air/fuel mixture is leaner, after the engine is fully warmed up, and that the spark jumping the narrower gap is always comparitively weaker.
http://en.wikipedia.org/wiki/Spark_plug
The gap adjustment can be fairly critical, and if it is maladjusted the engine may run badly, or not at all. A narrow gap may give too small and weak a spark to effectively ignite the fuel-air mixture, while a gap that is too wide might prevent a spark from firing at all. Either way, a spark which only intermittently fails to ignite the fuel-air mixture may not be noticeable directly, but will show up as a reduction in the engine's power and fuel efficiency. The main issues with spark plug gaps are:
* narrow-gap risk: spark might be too weak/small to ignite fuel;
* narrow-gap benefit: plug always fires on each cycle;
* wide-gap risk: plug might not fire, or miss at high speeds;
* wide-gap benefit: spark is strong for a clean burn.
A properly gapped plug will be wide enough to burn hot, but not so wide that it skips or misses at high speeds, causing that cylinder to drag, or the engine to begin to rattle.
As a plug ages, and the metal of both the tip and hook erode, the gap will tend to widen; therefore experienced mechanics often set the gap on new plugs at the engine manufacturer's minimum recommended gap, rather than in the middle of the specified acceptable range, to ensure longer life between plug changes. On the other hand, since a larger gap gives a "hotter" or "fatter" spark and more reliable ignition of the fuel-air mixture, and since a new plug with sharp edges on the central electrode will spark more reliably than an older, eroded plug, experienced mechanics also realize that the maximum gap specified by the engine manufacturer is the largest which will spark reliably even with old plugs and will in fact be a bit narrower than necessary to ensure sparking with new plugs; therefore, it is possible to set the plugs to an extremely wide gap for more reliable ignition in high performance applications, at the cost of having to replace or re-gap the plugs more frequently, as soon as the tip begins to erode.
Other notes say that narrower gapped plugs wear faster and that wider (to a point) gapped plugs more reliably ignite leaner air/fuel mixtures.
