VitaminT »
https://forums.nicoclub.com/vitamint-u9072.html
Tue Feb 10, 2004 3:30 pm
If you have a redtop or S13 blacktop then you will need the compressor inlet and outlet "adaptors" because these are angled different for the T28 compared to the T25. OR, you can cut the flanges off your stock adaptors and have a shop reweld them at the right angle for your hotpipe and inlet hose.
You will also need to get new gaskets for the turbine inlet flange, 02 housing, and maybe exhaust manifold. You MAY also want to upgrade to a HKS wastegate actuator.
As far as the decision between the Power FC or T28, all I can say is that you will have to have someting to control the new injectors and MAF. Whether this is JWT, PowerFC, Secret Services SSPL, SAFC you will have to have something. Then as you know you really need to have those injectors and MAF for the T28 turbo. So in reality it is BOTH, sortof.
I personally would not get cams, cam gears, valves, headgasket, UNLESS you are going to go ahead and do the internals.
On the last issue, I would say somewhere around 230-250@14psi, but the boost will fall off in the higher RPM.
