PandaS14 »
https://forums.nicoclub.com/pandas14-u20587.html
Sun Jun 12, 2005 9:24 pm
Devious, HOTNESS!
A little update for you guys. Unfortunately it does not include a vid/sound clip. My friend with the good camera just got it stolen.
After having done enough tuning today that it runs fairly well under all loads under 4500RPM, I've decided I'm going to try out Alpha N' (TPS based fuel map, instead of map sensor). I now know why almost all n/a ITB engines with standalones use this type of setup. This is because under low load (but constant acceleration) you can achieve map values that are the same as WOT. This is a problem because there are vastly different amounts of air entering the engine under the two conditions, but the standalone is looking up one area on the fuel map. so you can tune it to either WOT or low load, and get the correct a/f ratio, but not both. So I'm gonna try out a TPS based fuel map and see if that works better for me. I'll keep you guys updated as progress is made.
Oh and also, the fuel cut rev limiter that you can implement with MS is bad ***! You can set it to any rpm, works great, and it sounds like a friggin race car rev limiter. Love it. haha Also, it cuts until the engine has spun down 100rpm then pulls back up to redline and so on. With a relatively light reciprocating weight like mine, it cycles a few times a second, so it's really fast. super sweet.
