Practical LED Taillights for G50
TBrack
Car: none
I've been doing some research and looking at a lot of the newer Inifinitis lately and I have drawn up a sketch of LED taillights for the G50...
It uses the principle of the angel eyes with the notches refracting light (although you can't see it in the sketch) and uses LEDs to transmit the light through the rings...
I've decided to take over Wes's project and hopefully make them for anyone who wants them once I get the bugs worked out.
Modified by lasoyafan at 4:24 AM 1/12/2007
Modified by lasoyafan at 6:58 AM 1/13/2007
tkd_q45
Though I love angel eyes on the front, this design you propose will, IMO clash with the look of the rear. I think the circular design will not have any visual relationship with anything on the rear of the car.
Some time ago, someone had posted pics of a JDM LED setup that simply had LEDs firing in the stock reflectors. I'd go with something more along those lines.
Just my 2c - if it looks good to you - do it! Most important that YOU are happy with how you mod your car.
TBrack
Car: none
Yea I was noticing that also. I know I am definitely using the angel eye idea with the light refractions, but was not sure weather to do horizontal bars or circles.
I'll draw up a different one tonight.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
lasoyafan wrote:
What do you guys think?
Those are the kind im working on....
TBrack
Car: none
care to show me what you have so far? I'm going to home depot tomorrow to pick up some supplies...
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
And of course there is a previous thread where someone got to the mock-up stage, but never installed them as far as I can remember.
The trick is to make the computers see the correct current draw.
elwesso
2007 BMW M Coupe
maxnix wrote:And of course there is a previous thread where someone got to the mock-up stage, but never installed them as far as I can remember.
Those are the ones I have... I bought the incomplete project..
TBrack
Car: none
my searches can't find anything about this...
but anyway, there has to be a way to do it and fool the computer or you wouldn't see so many led tail lights out there.
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
It's all about the correct combination of resistors and bulbs to provide accurate current draw... right? Not easy, but no impossible either.
hannibal
Car: Red Line to Glenmont
I like the second sketch better. Its prolly easier too.
Break out the multimeter and get some measurements on the stock lights so you know what your aiming for with the LEDs.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
jdmtaillights (member JebsNYCQ45)
I hope you don't mind Wes:
I think you've already seen this one from an earlier thread:
Some other options:
http://www.i-cs.co.jp/hilltop/...2.htm
Some Headlight Options too:
http://www.i-cs.co.jp/hilltop/...l.htm
http://www.i-cs.co.jp/hilltop/...1.htm
Modified by lino at 10:06 PM 12/25/2006
TBrack
Car: none
not really what I was going for but those look nice!
I was going to be following this principle. http://www.mx6.com/forums/showthread.php?t=92243
Q451990
lasoyafan wrote:my searches can't find anything about this...
Do you mean LED tail lights on G50s? I haven't seen any in my area... but we are a little behind here in the land of cotton
The dash display is looking for ground (I think, either that or 12V) on a certain pin. I'm 99% sure it's ground. So to completely fool the sensor, just ground the output wire from the sensor. Otherwise, it would be necessary to run the appropriate value of resistors off of the circuit to emulate the load from the OEM bulbs. Assuming the sensor is sensitive enough to detect if the LED circuit, with it's very low load, if it went bad - you could retain the sensor function. Probably just something that someone (maybe me someday) will have to experiment with...
The acrylic rod idea looks very interesting! Maybe just a few high-power emitters at either end of the rods instead of multiple LEDs. From what I can tell the big issue with a home-designed LED board is heat management. LEDs are almost bulletproof if you properly manage the heat that they produce. The fact that I see so may professionally designed circuits loosing LEDs that are supposed to last the life of the car scares me a little.
Check out these Luxeon Emitters
http://www.lumileds.com/produc...Id=18
Heath
TBrack
Car: none
thanks a ton for the info! I will be working on it in a week or so, wish me luck.
Romeo5k
Car: 1995 Infiniti Q45~296k miles -- DEAD
2012 Nissan Altima 2.5 == 100,305 miles
errrr... Im kinda scared... Who wants to do my tails for me like the LED i just saw.. Those are fly to me... And i love em. so anyone wants to do mine? Ill send u my tail lights and watever else.
Black stallion
Car: 1994 Infiniti Q45
2006 Infiniti QX56
Don't be afraid grasshopper. I wouldn't mind doing some if someone were to work out the proper resistance etc. I am a wizz with a soldering iron, dremel, and various other gadgets, but am too wound up to do any figuring. Plus I don't have to pull out the Fred Sanford tri-focals yet.
This would be good therapy for me since I have yet to replace/fix my GIXXER 1000!
Romeo5k
welll.. im waiting for a sketch on how to do this... And / or if someone wants to do my tail lights.. ill send em to u. I think ill be the first in my city to have em. So that would look awsome!********************************************Anyone wanna do mine?
Modified by Romeo5k at 1:11 AM 1/4/2007
Romeo5k
err.. what happpened to this thread... i thought someone was supposed to be trying to make something happen..
Q451990
This little project seems to die everytime it goes from the "concept" to "development" stage
elwesso
2007 BMW M Coupe
las.. if you want ill let you take over my project.... email me for details... I have the lights and everything ready to rock.
TBrack
Car: none
bring it on
Romeo5k
Not fair.. im will to drive to yalls city and sleep in my car for 2 weeks to get these lights put on my car.!! ps: im laughing but im serious..
TBrack
Car: none
Romeo5k wrote:Not fair.. im will to drive to yalls city and sleep in my car for 2 weeks to get these lights put on my car.!! ps: im laughing but im serious..
I don't think that will be necessary. Once I finish the project Wes had, I will be able to make them for anyone.
TBrack
Car: none
I don't have Wes's lights yet, but I think I have found the solution and can design them so that it will be very easy to install and replace bulbs IF they go out. Circuit simulator program
Romeo5k
are the 93 tail lights the same as the 95.. For some reason they look different.. but some say they are the same. If they are the same, then good because i have the 93 tail lights sitting here in goot condition! FedEx is donwn the street from my house, and UPS is 10 mins away.. its called 2day Air svc!
TBrack
Car: none
Romeo5k wrote:are the 93 tail lights the same as the 95.. For some reason they look different.. but some say they are the same. If they are the same, then good because i have the 93 tail lights sitting here in goot condition! FedEx is donwn the street from my house, and UPS is 10 mins away.. its called 2day Air svc!
I don't see why they wouldn't be the same. Send them to me after I get the pricing done and can copy the design easily.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
Are there aftermarket lights, like clear bubble lights (Like the recent Altimas) available for Q's?
I've been looking. The angel-eyes lights are sexy and would look great on a black Q like mine.
BTW, I'm actually quite petrified about the whole chain guide issue. I'm afraid to look under my hood now. Because if in fact I do need to change the guides, I'm slightly broke after paying for this Spring Semester. So I don't think I can afford a big job like that.
I'm trying to at least get my car cosmetically modded (i.e headlights, taillights, bodykits, and the like.)
Question. Are there Exhaust tips available to change the sound of the exhaust? Not a whole exhaust system but just a bolt-on exhaust tip. My Q is so silent. I just want to add a little spice to the sound.
TBrack
Car: none
Haitian_King wrote:Are there aftermarket lights, like clear bubble lights (Like the recent Altimas) available for Q's?
To my knowledge there is no aftermarket tail lights in the USA, however with a little work I'm sure you could create a new lens to go on your existing lights...
As for the exhaust, remove the rear muffler and run pipes to a new high flow muffler OR just straight back. Exhaust tips will not help at all and are a joke, that is the only way to bring out the sound of the engine.
Haitian_King
T
Thank you very much. I regret that I'm not as electronically dexterous as you guys and making my own lights might be hazardous to my health and my Q. LOL
elwesso
2007 BMW M Coupe
You need to not do ANYTHING until you get your guides fixed.. What good is a nice looking car with a non running motor!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
