Not taking anything away from PPE as I am glad someone is stepping up to build headers for the M56 but I gained more than 30 hp gutting the factory manifold cats, ditching the secondary cats and building a custom 2.5" dual exhaust. Those factory tri-y manifolds make alot of low-midrange torque as well.ken in az wrote: ↑Fri Aug 21, 2020 1:57 pm30hp gain untuned
I am not coordinating a group buy as I doubt there will be enough interest, but if you want to reach out to PPE then go for it. Not steppin on my toes if you want to. Plus I don't have time to manage something like that.
Go to PPE's Instagram to check out more pics of the kit - solid kit and I'll be going back for potential resonator delete and or bypass valves for dual mode exhaust.
Agreed.TeamQX56 wrote: ↑Fri Aug 28, 2020 5:05 amIt would be nice to see before and after dyno numbers and pictures of your set up... we all here have a common goal/and to share the knowledge we have learned, "How can we make the M56" better.
So when you drop information Like that "Mr.DFW2011M56S", please share details...
Thanks.
Unfortunately gutting cats is not an option in states that require emissions inspections. Even so, I would rather have a properly designed header over a gutted cat any day of the week. Yeah it's a cheap, quick and easy DIY fix without having to remove your manifold and you do increase flow, but with gutted cats you create inconsistent pressure and velocity changes in your exhaust flow going into a much larger empty shell from your primaries which affects not only performance but the sound quality as well. Personally I feel like deleting everything from the OEM exhaust manifolds back and replacing it with a custom 2.5" X-pipe and performance mufflers is plenty good enough for our motors even with a custom tune.DFW2011M56S wrote: ↑Mon Aug 24, 2020 3:59 amNot taking anything away from PPE as I am glad someone is stepping up to build headers for the M56 but I gained more than 30 hp gutting the factory manifold cats, ditching the secondary cats and building a custom 2.5" dual exhaust. Those factory tri-y manifolds make alot of low-midrange torque as well.
