PPE Engineering Headers and Full Exhaust
armybrat
Car: 2012 M56x with Tech Package (sold)
Custom 2-1/2" X-pipe exhaust with OEM sport mufflers
HPS intake hoses
Uprev tune
splitnails wrote:
Mon Dec 25, 2023 10:57 pm
If I get the full headers/exhaust from PPE with high flow cats will that fix my P0420 code? Thanks!
It should, as the P0420 is a low efficiency threshold DTC...just means your cat is not cleaning the exhaust to the 92% threshold. The M56 is notorious for throwing this code after it reaches higher mileage. If you decide to go this route, it is recommended that you also tune the car since you are radically changing the stock set up.
808DRFTR
Car: 89 240sx KA24DE Swap
91 240sx SR20DET Swap
02 Sentra SER Spec V
01 QX4 4x4 Lifted
01 I30
11 M56 Sport
As stated above make sure you know what's causing the p0420 code 1st, make sure no other stored codes too. Sometimes could just be a o2 sensor, bad spark plug, headgasket, etc etc. Don't assume all p0420 is just the cat.
You'll be spending thousands on a new exhaust. Around 2k on just the headers and near that much more for install if not doing yourself
ibc
Car: Infiniti M56x
Does anybody know whether we need to add a heat shield above this PPE exhaust?
The OEM Y-pipe has a fully wrap-around heat shield. PPE has none.
Did the OEM heat shield protect the transmission or transfer case?
Or was it just for occupant comfort to reduce hot seats?
It had to be there for a reason.
808DRFTR
01 QX4 4x4 Lifted
01 I30
11 M56 Sport
ibc wrote:
Wed Jan 15, 2025 8:22 am
Did the OEM heat shield protect the transmission or transmission case?
No heat shields as there is almost no room for it. Mostly all aftermarket headers for various brands do not include shields. It’s something for OE use mostly and comfort
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The only things which positively need shields are the primary cats. Those are mostly to protect the outside world from the heat, park on dry grass without them and your car could look like a wildfire victim (and you might well start one). The pipes and rear cat don't hit those sorts of temperatures, so the shields aft of the main cats are mainly to prevent hot feet.
808DRFTR
01 QX4 4x4 Lifted
01 I30
11 M56 Sport
VStar650CL wrote:
Wed Jan 15, 2025 11:49 am
For OE yes, PPE does not run a primary cat only a secondary as a option
VStar650CL
Technical Expert
The rear cat will get hotter than normal when running without fronts, so if you have one it should be shielded. Without it, you really don't need anything.
808DRFTR
01 QX4 4x4 Lifted
01 I30
11 M56 Sport
I dunno I took the catless option lol
VStar650CL
Technical Expert
No worries then.
