Chaluska wrote:just do a brake fluid flush.. open the bleeders and let all the fluid come out, fill, bleed, repeat until fresh fluid comes out... shouldnt be a problem.. brake fluid is more corrosive than power steering fluid
It's a much bigger problem then you think, trust me.
pS fluid is petroleum based, while brake fluid is glycol based. The rubber portions of the braking system are specifically designed to stand up to long term exposure to glycol. They are not designed to come into contact with petroleum. When the 2 are mixed, the petroleum will cause all the rubber in the system to swell. You would be amazed how often people make this mistake. I see it every other month or so.
Get the fluid out now, preferably directly from the reservoir to start with. Don't push any more through the system then you have too, though I am sad to say the damage is likely already done.
When I see this at work, it's all or nothing. Everything with rubber gets replaced. The master cylinder, the brake hoses, the calipers/wheel cylinders, as well as the pro portioning valves on some vehicles.
Even if you flush the system now, chances are problems will show up down the road. The hoses leading to the calipers will collapse first, causing the calipers to stay on, then the calipers will start to leak. Around the same time the master will start behaving poorly and the pro portioning valve may act up.
You may have gotten lucky, and the fluid hasn't worked its way too far past the master. Personally I don't like to gamble with something as important as the brakes.
