Hey there this seems like it! do you know where those body grounds would be or a diagram of those?MisterH wrote: ↑Mon Oct 28, 2024 1:56 pmIf the drivers side works fine but all others don't function (even though the motors and switches are checked as good) then it's possible you have a bad ground. The key difference here is that the drivers side is connected to different ground terminals than the other three windows. I am not sure if it is any different for 1998, , but for 1999, the drivers side connects to body grounds M4 and M66. All the other windows are connected to body grounds M77 and M111.
Here's the power window functional description from page EL 194 in the manual:
Power is supplied at all times
- from 40A fusible link (letter f, located in the fuse and fusible link box)
- to circuit breaker terminal 1
- through circuit breaker terminal 2
- to power window relay terminal 3.
With ignition switch in ON or START position, power is supplied
- through 7.5A fuse [No. 11, located in the fuse block (J/B)]
- to power window relay terminal 2, and
- to smart entrance control unit terminal 33.
Ground is supplied to power window relay terminal 1
- through body grounds M4 and M66.
The power window relay is energized and power is supplied
- through power window relay terminal 5
- to power window main switch terminal 1,
- to power window sub switch terminal 5.
MANUAL OPERATION NBEL0102S01
Front Door LH NBEL0102S0101
Ground is supplied
-- to power window main switch terminal 3
- through body grounds M77 and M111.
WINDOW UP
When the front LH switch in the power window main switch is pressed in the up position, power is supplied
- to front power window regulator LH terminal 2
- through power window main switch terminal 9.
Ground is supplied
- to front power window regulator LH terminal 1
- through power window main switch terminal 8.
Then, the motor raises the window until the switch is released.
WINDOW DOWN
When the LH switch in the power window main switch is pressed in the down position, power is supplied
Ground is supplied
Then, the motor lowers the window until the switch is released.
Front Door RH NBEL0102S0102
Ground is supplied
-to power window main switch terminal 3
NOTE:
Numbers in parentheses are terminal numbers, when power window switch is pressed in the UP and DOWN
positions respectively.
MAIN SWITCH OPERATION
Power is supplied
- through power window main switch (5, 6)
- to front power window sub-switch (3, 4).
The subsequent operation is the same as the sub-switch operation.
SUB-SWITCH OPERATION
Power is supplied
POWER WINDOW
System Description
- through front power window sub-switch (1, 2)
- to front power window regulator RH (2, 1).
Ground is supplied
- to front power window regulator RH (1, 2)
- through front power window sub-switch (2, 1)
- to front power window sub-switch (4, 3)
- through power window main switch (6, 5).
Then, the motor raises or lowers the window until the switch is released
You must have missed what I said earlier, so please pay attention. THERE IS NO GROUND IN THE THREE PASSENGER DOORS. They all ground through 1) the "neutral" throw on the corresponding Master Switch and 2) then in series to the child lock. If either the neutral throw or the child lock has no contact, the window has no ground and won't work. Since the "neutral" switch throws are individual for each window, the only one which is likely to affect all three at once is the child lock.bobo99121 wrote: ↑Mon Oct 28, 2024 3:55 pmBut brings me to what the other poster said above. I am missing ground on the three windows in the down position where would that other body ground be? I checked the one on the front kick panel but do you have any idea where the other grounds would be for this circuit?
VStar650CL wrote: ↑Mon Oct 28, 2024 7:44 pmYou must have missed what I said earlier, so please pay attention. THERE IS NO GROUND IN THE THREE PASSENGER DOORS. They all ground through 1) the "neutral" throw on the corresponding Master Switch and 2) then in series to the child lock. If either the neutral throw or the child lock has no contact, the window has no ground and won't work. Since the "neutral" switch throws are individual for each window, the only one which is likely to affect all three at once is the child lock.bobo99121 wrote: ↑Mon Oct 28, 2024 3:55 pmBut brings me to what the other poster said above. I am missing ground on the three windows in the down position where would that other body ground be? I checked the one on the front kick panel but do you have any idea where the other grounds would be for this circuit?
So correct me if I am wrong you are saying the other poster is wrong .There is not an independent ground or power feed for all other windows besides the front driver side. And I get what you are saying but shouldn't there be an easy way to tell if the master switch is bad besides just replacing it with another one?VStar650CL wrote: ↑Tue Oct 29, 2024 4:08 amFollow the blue path in the diagrams. Here's the previous page for clarity, you can see the "F" off-page link goes directly to ground and there's only one ground wire. The rear windows are set up identically to the passenger front. The only ways a window can not have the blue path is if the Neutral throw in the Master is open circuit or the child lock is open circuit. There are no other possibilities.
oh and i was wrong it is a 1999 jnrar05yxxw044068VStar650CL wrote: ↑Tue Oct 29, 2024 4:13 amPS - I'd strongly suggest entering your VIN into InfinitiPartsDeal.com to get the right switch part number, then check it against what's in there. I can't tell you how many DIYers I've seen get screwed by Amazon components purchased using MMY or appearance instead of the part number.
Yes, he's wrong. There are probably grounds inside the other doors for other systems like locks or mirrors, but none of them apply to the windows. The window motors can get ground only through the Master Switch. If it wasn't set up that way, the Master and Slaves could blow one another up when worked opposite. The only passenger windows which won't be set up that way are ones with Auto (those actually have a LIN which communicates to the Master and BCM), but I don't see any reference in the FSM to a passenger side Auto in '98 or '99.bobo99121 wrote: ↑Tue Oct 29, 2024 10:54 amSo correct me if I am wrong you are saying the other poster is wrong .There is not an independent ground or power feed for all other windows besides the front driver side. And I get what you are saying but shouldn't there be an easy way to tell if the master switch is bad besides just replacing it with another one?
I don't see any functional or schematic differences in the window system between '98 and '99. There may be some changes in pin locations and wire colors (I didn't go over it exhaustively), but it looks the same and definitely works the same. Nothing jumps out.
Ok thanks. Also yeah so I looked on rockauto and crossed their parts. The window switch numbers for the 1998 are definitely different than then 1999 switch. So something internal to the switch must be different even though they look identical even same pins. That seem true to you too? or anything on the wiring digram that strikes you as different internally on the switches.VStar650CL wrote: ↑Tue Oct 29, 2024 11:28 amYes, he's wrong. There are probably grounds inside the other doors for other systems like locks or mirrors, but none of them apply to the windows. The window motors can get ground only through the Master Switch. If it wasn't set up that way, the Master and Slaves could blow one another up when worked opposite. The only passenger windows which won't be set up that way are ones with Auto (those actually have a LIN which communicates to the Master and BCM), but I don't see any reference in the FSM to a passenger side Auto in '98 or '99.bobo99121 wrote: ↑Tue Oct 29, 2024 10:54 amSo correct me if I am wrong you are saying the other poster is wrong .There is not an independent ground or power feed for all other windows besides the front driver side. And I get what you are saying but shouldn't there be an easy way to tell if the master switch is bad besides just replacing it with another one?
According to your VIN, the correct switch should be a 25401-0W000 or 25401-0W010. It's out of production with Nissan/Infiniti, but there are undoubtedly clones available given the popularity of the QX4.
The easiest way to trace any ground issue is by hooking a test light gator to 12V instead of ground. Then the bulb will light when a ground is present at the tip. By probing the blue circuit from the Master to the passenger front door, it should tell you at what point ground is going away. You should get a light at both Blue/White and Blue/Yellow at the Master connector (by way of the Neutral throws and the child lock). If not, the problem is inside the switch (or it's a wrong switch).
So yeah got the 99 infiniti switch off of ebay and connector plugged in but absolutely nothing works and it is definitely not the right switch so it is the switch i did purchase. Yeah I will check to see where I am losing ground, but you think if driver side window works in both directions-- that must mean that the switch has the proper grounds and power for the other windows to work if the switch was working properly. Because if not-- then the other windows could be losing a ground because the ground wire they use is different and on a different circuit but just thinking out loud.VStar650CL wrote: ↑Tue Oct 29, 2024 11:47 amThe easiest way to trace any ground issue is by hooking a test light gator to 12V instead of ground. Then the bulb will light when a ground is present at the tip. By probing the blue circuit from the Master to the passenger front door, it should tell you at what point ground is going away. You should get a light at both Blue/White and Blue/Yellow at the Master connector (by way of the Neutral throws and the child lock). If not, the problem is inside the switch (or it's a wrong switch).
VStar650CL wrote: ↑Tue Oct 29, 2024 11:54 amPS - There are three different FSM's for the '99's depending on serial number, and I'm not sure what the differences are. However, I got those p/n's by plugging your VIN into the parts database, so they should be right. Try using those numbers on the Part Number Search tab in Rock, see what it comes up with.
I checked all of those and key on they all have ground and lightup test light. I can get them not to light up the test light by hitting the child lock switch and it removes ground. Then I switch that back and ground goes away. for all of those wires I have ground key on. When I switch the switch for that circuit up or down I forget which one excatly one way itll lose ground on that circuit. I have a feeling I am loosing power to them not ground.VStar650CL wrote: ↑Tue Nov 05, 2024 11:28 amI take it back, there are two FSM's, the third one shown in ASIST was a supplement. The VIN cutoff is X*060000, from X*060001 is a different FSM. So your ride uses the earlier version, which electrically appears to be identical to the '98.
That said, if you aren't willing to break out a test lamp and verify the ground path, then you aren't going to find the problem. The fact that the driver's window works means you positively do not have a global ground issue. So hook the gator to 12V, make sure it lights up to a chassis ground, then back-probe the Blue/Yellow, Blue/White, Red/Black, Green/White, White/Black, and Black/White wires at the master. Those are the six motor wires for the passenger switches, and they should all light the lamp if the master is grounding them. If none of them light (which I strongly suspect will be the case), it's 100% certain that your switch is wrong or f#cked.
bobo99121 wrote: ↑Tue Nov 05, 2024 10:36 amVStar650CL wrote: ↑Tue Oct 29, 2024 11:54 amPS - There are three different FSM's for the '99's depending on serial number, and I'm not sure what the differences are. However, I got those p/n's by plugging your VIN into the parts database, so they should be right. Try using those numbers on the Part Number Search tab in Rock, see what it comes up with.
what serial number? I would like to see wiring diagram for mine exactly to make sure there isn't something weird with the ground not being on the switch for the rear 3 windows (or I mean that the switch gets a ground for those three from a different source than the driver window) if you think that is not possible.
So what you're saying is this--
If driver window works up and down fine at the master switch front driver side.
The rear windows motor work manually when tested
Then the problem must be in the switch board and the switch is bad even the new one I purchased that does exactly the same thing as the other one-- that the switch must be bad. I just have trouble believing that I think we are missing something on the feed to the switch or a ground on the circuit that is just not there period. It doesn't look to me like anything has failedo n the switch no bad solder etc., and this seems like a problem where just one leg is missing that effects all the 3 windows
so i pulled the passenger side off and the switch works fine going up but it is missing ground when you go down. motor works fine you hear it trying to go up but yeah doesn't work in the down. It gets power but doesnt get the ground on the down which i think is true on all of themVStar650CL wrote: ↑Fri Nov 15, 2024 10:23 amCheck those wires at the slaves. Whatever the problem really is, that should point to it. Hopefully it isn't a bad splice, that can be a nightmare.
No, sorry, I don't do phone consults.
That shouldn't even be possible. They all ground through the master, but they all have their own individual wires and their own individual switch at the master. For them all to have no ground only in the down position would require three identically broken wires. Back to blue poops.bobo99121 wrote: ↑Sun Dec 08, 2024 9:29 amso i pulled the passenger side off and the switch works fine going up but it is missing ground when you go down. motor works fine you hear it trying to go up but yeah doesn't work in the down. It gets power but doesnt get the ground on the down which i think is true on all of them
