IanS »
https://forums.nicoclub.com/ians-u23642.html
Wed Jan 30, 2008 8:23 am
Don't jump to conclusions just yet, the passenger switch failed on mine and neither switch would work, I just pulled the switch out and soaked it with electrical parts cleaner, its worked great ever since. The easiest way to tell if its the switch or the motor, pull off the door panel and unplug the two wires that go to the motor, use some jumper wires to manually feed battery voltage to the motor, if it works, fix the switch, if not, replace the motor.
