Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Wed Dec 27, 2006 10:37 am
no custom lines, you actually have to block off the rear banjo bolt that used to feed the hicas rack. first you have to take the PS pump off the engine and take it apart the rear housing. inside you will find the impeller with a bunch of little blades you can remove. remove all of them. after that put the pump back together. then you need to epoxy or weld over the holes in the banjo bolt, then use some teflon tape to seal it up when you screw it back into the rear housing. i think thats all there is to disabling the hicas side of the pump, someone correct me if i F'd something up.
