BiXLL »
https://forums.nicoclub.com/bixll-u76819.html
Sat Sep 27, 2008 2:55 pm
subscribing, I am degreasing power steering pump area in the morning to try and locate a small leak also! I can not tell where its coming from, but always leaves 2 sposts the size of a silver dollar on driveway where parked.
CM, before ordering that hose, I would check out a local hydrolic shop. I have found that it is actually cheaper to have them make up hoses then to order OEM stuff like this. You would be amazed at all the different fittings and such they have right on hand to be able to make just about anything you would need.
