Erm.....I have a full tune up on my car.......kapower240 wrote:yea thats how mine is too. but yea am gonna get the distributor cap and rotor new tomorrow. probably have to wait a while for them to receive it but ill try that then wel see what happens
Exact same thing was happening to me so I got under the hood and checked and found a lot of little problems that I had been overlooking. I had replaced my radiator but forgot to tighten up the clamp where my intake piping connects to the engine. Had to take the intake off to get the radiator out. Found two vacuum hoses that were not capped off. I also checked under the car and found that the exhaust gasket and one bolt had completely come off where the catback and the test pipe connect. I replaced the gasket and bolts. Fixing these problems corrected my power loss, idling problems and noise reduction. My car would have erratic idle where it used to idle at 1000rpm always. After startup it would bog down and almost completely die when I would shift into gear and give it the gas. Between 2500-3000rpms it would lose power and bog down. I also noticed that my exhaust was louder than normal and the car did not accelerate the way it did before.kapower240 wrote:Hey guys i need some hep with some power loss i have been dealing with and its starting to get on my nerves. wel the power loss is from 2500-3000rpms and my tone from my exhaust goes from smooth to an erratic tone when i lose power. so i was thinking that it might be either the maf failing or the fuel pump not giving me enough fuel. and the other thing is that when i have gas pedal pressed lightly its hard to notice but when pedal is at least more that 1/4 the way down you can feel it. it also happens randomly so sometimes i dont have power loss and sometimes i do. by the way i have 1993 240sx HB w/ 97 KA24DE with 280k miles ond the body and 110k on the engine with few basic mods I/E. well hope you guys can help
Anybody know how often you should change your fuel filter? I changed mine after I bought the car about a year and a half ago.240fstbak wrote:i had a very similar problem and i found that it was fixed by replacing the fuel filter and never using phillips 66 gas again!
Uh oh.....sounds like somebodies got the EXACT same problem my car has.......sticking valve........:/kapower240 wrote::::::::UPDATE:::::::
and another thing is when i lose power the engine gets shaky specialy with throttle fully open as if i was running on 3 cylinders but it happens randomly.
I did the same thing as well as sea foamed my car 2 times and yes it does help the problem for a little while but does not fix it permanently.Sonikfuri wrote:**UPDATE**
I tried putting in the fuel injector cleaner, and so far it's helped out drastically. I can still feel the power cut out during hard turns, but I also didn't follow the directions perfectly (I couldn't just "waste" 1/2 tank of gas). So I'm going to run my (now) full tank down and pour another bottle in...now i just gotta change my ignition coil.
Sorry its takin me so long to reply.240_ESEX wrote:KaPoweredHatch did you switch out those injectors. I've got this problem just like everyone else, only I pulled out my plugs to look at the wear on them and 2 and 4 have unburned fuel on them, still wet. 1 and 3 are fine they burn like they're supposed to. Also there is litterally fuel coming out of my exhaust along with white smoke. Not like pouring out or anything, but spiting it out, and the longer or harder the car's running the more that comes out. Anyone able to solve this problem, or other idea's of what it might be?
UPDATE:240_ESEX wrote:KaPoweredHatch did you switch out those injectors. I've got this problem just like everyone else, only I pulled out my plugs to look at the wear on them and 2 and 4 have unburned fuel on them, still wet. 1 and 3 are fine they burn like they're supposed to. Also there is litterally fuel coming out of my exhaust along with white smoke. Not like pouring out or anything, but spiting it out, and the longer or harder the car's running the more that comes out. Anyone able to solve this problem, or other idea's of what it might be?
Yea it may have taken me a long while but at least I kept everyone udated.mmm240 wrote:^ a man of his word!
