hurddawg »
https://forums.nicoclub.com/hurddawg-u170.html
Thu Mar 18, 2004 12:35 pm
got it. Pages 54-57 describe that. it looks fairly simple to operate.
Starting on page 54 from the big number 1
1. On the main menu select "setting". (#1 in the pic is saying using the arrows to select, #2 to continue)
2. In the "Settings" menu select "boost" (the pic is the same but the unumbered one says "go back", "return", etc
Page 553. This is the boost setting screen. Select the number you want. (The pic on the left from left to right..."Setting number"...."Set boost pressure"...."Base duty"...."fuzzy logic value??" The pic on the right is mostly the same, but the right button is used to change boost pressure or base duty.) P.S. these are the 4 staged boost pressures btw
Once you moved over either pressure or duty, use the up or down arrows to adjust the value. Use the left/right arrows to move between the values and presets. The last box is just telling you how to return to adjust the other presets
page 56
On setting the boost pressure...The 4 presets can be adjusted between 0.5bar to 2.0bar. You can set the boost pressure above the actuator but not below its setting.
On solenoid valve duty control...With the Power-FC controlling the boost pressure, the duty control used by the solenoid valve, at the set boost pressue, is how boost is controlled. (essentially saying the boost is controlled by the duty valve you set)This duty control, turns the solenoid valve on/off rapidly and variates the percentage and length of time the solenoid is in the "On" position and that is how it controls the boost. Duty at 100% and the solenoid is always on, at 0% the solenoid is always closed.
On the relationship between boost pressure and Duty...Normally, the pressure is controlled by the actuator. <Cut out a bunch of crap> When the solenoid is off it allows boost pressure to reach the actuator. vice versa for the "on" position. Higher the duty, higher the boost pressure and vice versa.the duty value must be adjusted so that it is near the boost pressure. Once the duty value is close enough to the boost pressure, the power-fc will automatically adjust the value. But if the pressure doesn't reach the set boost pressure you must adjust the duty value.
page 57If boost pressure doesn't attain/passes set boost prsssure...
-If the boost pressure doesn't reach the set pressure a) the duty value is too low. In this situation, adjust the duty value higher, a little at a time.-If the boost pressure is much higher than the set pressure a)The duty is too high, in this situation lower the duty.
too small a turbo, or unobtainable boost pressure maybe another reason why the set pressure is not reached.
Fuel cut when boost passes its setting- If the set boost pressure is exceeded by 0.25bar the PowerFC will cut fuel.
To control the boost pressure other than the power-fc...from main menu goto "etc", -->"Function Select" and set Boost Cntl kit to "no" As long as this option is selected, the Power-Fc will control the boost. However even if you don't use the boost control kit, The powerfc will cut fuel if the set pressure exceeds 0.25bar from the set value.
