1) I dont really know, it depedns on shop and what else they do at same time but its not real labor intensive so it shouldnt cost the world.
2)if lines are clogged, replace, maybe put in a transmission cooler to bypass a possibly clogged heat exchanger and/or lines.This also shouldnt cost the world.3) For sure,4) Depends on its appearance and what u find is going on.5)If it slips it could go anytime I doubt your pressure check will come out as good.
Remember we are hoping for the best case scenario w/ cheap fix with the above method.It is just as likely (more so actually) that your seals are shot due to an overheat at some point and this is cause of your slippage)The transmission could be shot, a good tech will be able to determine which it is.Keep in mind you also need an <honest> tech as the temptation will be tremendous for a shop, especially like an AAMCO. to say it needs. a transmission replcament vs just fixing a clog that may exist.
Good Luck friend and hope to see your Q alive and well at the Indy meet on the 28th.
Fred..
