Possible S14 SR20DE flywheel match
rotorific
So at Jhot we just got in a bad engine. It is an S14 SR20DE RWD and the flywheel looks to me like it is the exact same dimensions as a CA18DET clutch/flywheel 225mm right? Ill take pictures later on today.
-Gabe
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
sr20 rwd flywheel bolts on to ca, but its bigger diameter.
you have to use a different starter to acount for the change in ring gear diameter. you also ay have to clearence the inside of the bellhousing for pressure plate cfitment, depending on which clutch setup you use.
Masterdebater
Car: 1989 nissan 240sx coupe
what about an sr20 clutch? could u get an sr20 clutch onto a ca?ive never seen a sr clutch up close so i wouldnt know...
float_6969
You can use an SR clutch if you use an SR flywheel with an S12 hitachi gear reduction starter. (no nose cone). You can use a regular S12 starter, but you might have to grind the nose down a bit to clear the pressure plate.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
crazy! who woulda thunkit?
bentvalves
Car: 89 Silvia K's
float, do you ever feel like a broken record?
answering questoins over and over and over and over and over and over again.......the same questions.
r34 gtr
i just try and come up with even wittier answers.
float_6969
My short term memory is only 2 min long, so as far as I know, I'm NOT repeating myself.
It's great for the forum and sex. SHE doesn't like it, but hey, I don't remember that either!
r34 gtr
youre god damn right. basically the way i live my life. "honey could you help me with this?" "who the hell are you?! get out of my house!" then repeat with different broad (or dame).
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
Dude, you should stop letting prostitutes sleep over. That's the first rule of the game. No wonder you can't remember their name .. :-)
rotorific
I've already known this for a while..... don't treat me like I'm some ****ing dumb ***.
I guess everyone saw SR20 and didn't even realize I said SR20DE.
The S14 SR20DE clutch disc is 225mm in diameter just like the CA, just like the KA. I don't know if the S13 SR20DE is the same or if this is just a RWD size.
If anyone could tell me a measurement from tooth to tooth on a CA flywheel I will check it out during my break at work.
edit. HEY I tried to change my thread title, when I created this I realized after I originally posted that it said DET. DOH! Anyways I see the confusion.
-Gabe
Modified by rotorific at 6:36 AM 3/7/2007
ca18datsun510
good job dumbass!!!
rotorific
ca18datsun510 wrote:good job dumbass!!!
Man I so woke up on the wrong side of the bed.
rico05
Car: 1992 RMS13 w/ CA18DET
Good info guys!
I didn't know we had a JHot guy on here. You guys sent me an awesome motor alomst exactly 3 years ago. Still running strong. I have been talking up the new Denton store too all my minions on http://www.texasnissans.com You should join there too (*end shameless plug*)
rotorific
Phyrx
Car: 2001 Audi TT Quattro
My CA18DET I just received from JHOT was in bad shape...
It was hydrolocked when I first got the motor. I managed to turn the motor over and get it to start (Dont ask how) and than it starts knocking AND overheating... all within 1 day... Pulled the head and it had a blown METAL HEADGASKET and pulled the bearings and a few of them are chewed up pretty bad.... and I paid 1500.00 shipped.
I called up JHOT and they didnt want to do anything about it except for buy me a headgasket.... sio I just figured Id give up before things got bad... lol
Anyways... I cant wait to hear my CA run! But man was the Shipping from JHOT great!! Took 2 days.
All in all, I woulkd most likely buy rfom you guys again... I think I just got unlucky.. no point in whining.. what good is a CA on a stock headgasket anyways??
oversteer180
Car: 1990 Silver 240sx
So did you ever confirm that the ca and sr20de clutches are interchangble?
r34 gtr
and how did you already know i sleep with "ladies of the evening"?!
ca18datsun510
rwd n/a and turbo ca clutch/flywheel are the same.
i believe same goes for sr, so that would mean it worsks.
rotorific
Phyrx wrote:My CA18DET I just received from JHOT was in bad shape...
HEY
I'm the one you talked to. The only reason we suggested to replace the headgasket was that we didn't have any CAs instock to send you as a replacement. I need you to call me so we can get your motor fixed because you shouldn't have to pay for anything!
-Gabe
rotorific
ca18datsun510 wrote:rwd n/a and turbo ca clutch/flywheel are the same.
Well I'm in a better mood today thank god.
The measurements I got were: clutch disc is 225mm, flywheel is 275mm on clutch side, from tooth to tooth on the flywheel it is 280mm.
I took pictures of the disc/flywheel and some part numbers on them. I will be posting them up today some time after 1, we are getting our container today so I will be tied up a good bit.
-Gabe
r34 gtr
i still dont know how you knew of my constant single night romantic entanglements with ladies who work after the sun goes down.
Phyrx
I have already tore the motor down
And I am ordering CP pistons for it..Already got the Calico Main & Rod bearingsAnd a Cometic metal HG along with ARP studs
nissanic89
Car: 89 nissan coupe
so if i want a lightend flywheel i can get one for and sr, and use a sr clutch and use an s12 starter from the ca18et engine?
ca18datsun510
yes, yes you can.
nissanic89
go
ca18datsun510 wrote:yes, yes you can.
good deal thanks, ive been looking for a loophold and more clutch options for motor, and i wanted a flywheel too so im exciteded about hearing this. Ive heard it but wasnt sure
rotorific
I had to copy and paste everything...bleh
rotorific
Well we got a CA18DET back today. I can tell you for sure the S14 SR20DE flywheel is no where near the same as the CA. The width and diameter are off by a couple of Millimeters.
Oh well.
zero_gripS13
Car: soon to be 95 s14 hopefully
rotorific... i emailed jhot like 5 days ago trying to gt a quote on a ca18det motor set shiped to ohio 43232..
could u email me with a quote..
thanks
[email protected]
float_6969
Thanks for all the hard work in trying. Sucks that it didn't work out...
