If you talk to ARP reps, they will recommend it. On my Tomei's they had the reliefs so it was doable in the car even with the radiator in (bump start with the starter). When I finally got around to doing it on mine (maybe 5-6k miles in.. yea pretty late). A couple of the studs had loosened a bit to less than spec.Shocker wrote:Gawd, Darius has HKS cam shafts, therefore he would need to remove them in order to retorque them... are you sure thats required?
damnit, not looking forward to that...... Its such a pain in the *** to have to remove the front bumper, IC, piping, e-fans, rad, accessories, timing belt then pull the cam... But I guess if it keeps the head down and the motor alive its a must.gawdzilla wrote:If you talk to ARP reps, they will recommend it. On my Tomei's they had the reliefs so it was doable in the car even with the radiator in (bump start with the starter). When I finally got around to doing it on mine (maybe 5-6k miles in.. yea pretty late). A couple of the studs had loosened a bit to less than spec.
In that case what would the answer be??More torque on the bolts??I say that would streatch and weaken them further.cdorhout wrote:Matt has plans to push upwards of 30psi of boost this summer. The stocker is not an option.
All this is exactly what I think as well,they may recommend retorquing but they are also only reuseable so many times...everytime you retorque them and especially increase the load you will weaken them.Darius wrote:Shocker - I installed the gasket according to their specs except I do not know exactly what the Ra was. I am sure from this pic that you can see how smooth it was. The only thing Cometic is "better" at than other companies is heat resistance, but who needs heat resistance when you should have a functioning cooling system? EPDM>>Viton when it comes to sealing.
cdorhout - I sold my stock cams so no I don't have them anymore. If I could do it all over again I would have gone with a cam that I could reach the head nuts through. Popping valve covers is no comparison to having to remove the timing belt and cams and radiator and crank pulley and belts and covers and CAS and cam pulleys dammit it is not easy.
If I remember right and I could be wrong here, ARP studs are torque-to-yield which means if you overtorque them (beyond the elastic limit or "yield") they will stretch and not return to their original length.
Until I get a leakdown test completed, I won't do anything drastic.
Carl, care to enlighten us more on this o-ringing?Carl H wrote:i honestly wouldnt mess with an mlshg they seem to be nothing but trouble...if you want something that will hold boost then do the right thing, use the stock hg and have the block oringed, that will hold 30psi easy in conjunction with arp bolts and is gaurenteed to seal.
