So your pretty much saying those that are planning on running a HX series turbo or another should have this done if going over 25psi? And how much does this go for?Carl H wrote:off the top of my head the orings are cut to fit each motor and typicaly are made of mig wire or piano wire.they work well tho, if i had, had the chance to had my block oringed then i would have but i dont plan on running more than 25psi max...
See heres where my problem lies, I'm doing a complete rebuild right now(stroker/forgies), I DO NOT want to have to open up my ****ing block again! I did that way to many times last year and frankly am quite sick of it.Carl H wrote:off the top of my head the orings are cut to fit each motor and typicaly are made of mig wire or piano wire.they work well tho, if i had, had the chance to had my block oringed then i would have but i dont plan on running more than 25psi max...
I know, however I am building my block right now so it was a generally question....eh? wrote:Not a good option if you've alread built your block. Why strip the block and take it back the the machine shop to be o-ringed?
Lots of RB's making excellent power on metal HGs' and not leaking (just haven't heard of any RB with a cometic making any good power..)
I would definitely go with cosworth on this one.eh? wrote:Not a good option if you've alread built your block. Why strip the block and take it back the the machine shop to be o-ringed?
try it out and let us knownoodl35 wrote:I would definitely go with cosworth on this one.
i can't be sure just by the leak down; that only means the compression chamber hold pressure fine, but hte oil and water jacket maybe where the leak is that the leak down can't detect. you see my point ?Darius wrote:I haven't decided what I want to do yet. I am not fully convinced that there is a head gasket problem after the leakdown test came back as good as it did. There are a ton of other upgrades and mini-projects I'm doing on it right now that are keeping my mind off of the issue. Too stressful to think of yanking the head again with all the labor involved. Honestly takes me about a week to pull it and put it back together with all the other stuff I have going on.
those numbers look kinda high to me .. usually i see around 3-10% on a healthy motor. could very well be a variance in the leakdown tester itself. what psi are you testing at?Darius wrote:Just finished the leakdown test and here's the results. Each cylinder was in the "low" leakdown zone of 0-40%
1-30%2-30%3-25%4-25%5-30%6-20%
