One Crazy Max wrote:
i can assure you that you are wrong, and you kind of contradicted yourself although it might not be that obvious. stronger brakes will slow you down faster than stock brakes, even with the same tires.
take the 350z/G35 for example. both those cars had options for upgrading the stock brakes to the all around brembo package, and guess what...they did stop better with the brembos, with the same tires.
brake force and tires do go hand in hand though. if you have upgraded brakes, but crap tires then you will notice slight increase in the stopping power, but not much, and vice versa. but then if you match the upgraded brakes along with a really good tire, the difference in stopping power between stock and upgraded would be night and day, and im sure you can agree with me.
Well, if you say so. But you gotta admit that the average joe will never REALLY need those huge brakes. They'd be mostly for show. If you've got ABS, and you drive like a normal person (and by that I mean you don't go 50+ mph over the speed limit), any modern stock car will do its job and do it well. But then we all know that.
Edit: While we're on the subject of brakes and tires... Max, have you ever used this product
http://www.duragloss.com/product.asp?pid=332
I stumbled upon it one day, read about it a little. It has won a few awards, so I know it's more or less legit, but i'm still a bit skeptical.
