and even if you could get a tool in a intake manifold to port and polish it, its not worth the time to do it. Do you know how much labor would go into that? And the result would be like a couple hp maybe? And to fully see the result, you would need to bench flow it. You cant see the gain on a dyno...it will be too minimal.
Save your money and buy a greddy manifold. The cost of extruding a manifold is pretty close to the cost of a greddy manifold. Plus it looks better.
tenkawa_akito wrote:Relieving backpressure of the exhaust system will give more performance gains than opening up the intake path
And this is very true....you dont want the intake path to be completely smooth. You want your intake port to be a little rough so the air and fuel can mix. And there is swirl and other stuff to consider.
