Did they bother to build the engine or get a proper tune? or did they just go for cheap and fast? KA probably gets a bad rap b/c lets face it the 240 is a cheap car lots of kids buy them and want to boost it cheap to go fast, then soon as it blow up they blame poor engine design. Even if you went SR you need to build and tune it properly.lulu44321 wrote:out of every body that i know that took a na motor to turbo status has lasted no more then 1 year the ka was not designed for increased cylinder pressure
Shay Laren buddyxckid wrote:i want names of that girl now!
If your uncomfortable with the idea of boosting the KA dont bother. Many people have their own ideas on what is good for them. People on ka-t section will obviously vote for a ka-t cause of larger engine, usually more bang for buck, idea of swapping out a perfectly fine engine just to gain 50 hp at the cost of 2,000 dollars. SR people will argue that their engine internals are better, more parts, more reliable, etc.lulu44321 wrote:out of every body that i know that took a na motor to turbo status has lasted no more then 1 year the ka was not designed for increased cylinder pressure
Which specific points in the engine would you consider to be insufficient for increased cylinder pressure?lulu44321 wrote:out of every body that i know that took a na motor to turbo status has lasted no more then 1 year the ka was not designed for increased cylinder pressure
\480sx wrote:
Shay Laren buddy
LuLu, a stock ka has put down over 500 HP, a few times. STOCK BLOCK. Rods failed at that hp, twice, which is to be expected.
The SR doesnt use the 300zx filter, ffs... It might work with a z filter, but it also works with a Ka's filter. Also, there is no 'shipped overseas' parts to worry about, the SR has a strangle hold on america. US companies manufacture parts, and Japan sends boatloads of SR stuff to be sold here without jacking up the prices by to much.
Again, do some research and make your own choice. From the sound of it you should go SR, its going to be a much easier road for you.
The coolant situation isn't really that big of a deal IMO. How long does air come into contact with the walls of the intake manifold. In an intercooler, air is divided into small portions so that energy can be transferred to the metal that the intercooler is constructed of. It has to be divided into such small portions because of how fast it is traveling. In the intake manifold, the mass amount of air and length of the runner section that actually has heat transferred to it isn't enough to significantly heat the intake charge IMO, as long as you keep coolant temps under control. IAT is typically around 110* for me at about 14psi, so 180* doesn't allow for much heat transfer to occur. I don't really see any difference in plug color from cylinder one to cylinder four, so obviously there isn't a lot of intake heating occuring on cylinder one, which would be the most affected by design.480sx wrote:You cant call that stuff design flaws because the engine wasnt designed to run 30 psi of boost Cory... Its design was intended to produce low to mid range TQ for a 4 cylinder, and it does its job.
IMO, the main 'design flaw' i see on the Ka is the coolant discharge coming out of the intake manifold. Super heating your charge air FTL. I understand that emissions can be reduced slightly by hotter air, but FFS, no other motor that i know of does that, its a retarded design.
Maybe you should run a miata motor... Lol from your statement you hate the majority of all modern engines.
Also, have you ever lifted a head?! Fvk, AMS's build was fine with 11mm studs till the iron cylinder walls cracked at around 1000 crank hp.
Yes it can, with solid lifters, valve springs and retainers, Greddy intake mani, cams... etcnissanfanatic wrote:SRs can spin to 9000rpm or so with supporting modifications.
sunnys14 wrote:noobs noobs noobs, OP you are are noob
I've built both SRs and KAs. They both have their ups and downs.
Any engine can be fast if you put your money into it.
SR's have alot of aftermarket support. KA's lately has gotten huge aftermarket support. So both have alot of good parts to buy to be fast.
People saying SR's is better because it can rev higher? My KA revs to 7200 compared to a SR's 7500.
KA's are weak because they have poor flowing heads?Get your stuff straight bro, have you even seen a SR head? Weakest head EVER. Rocker arms are the best stuff...
Alot of SRs guys won't go past stock turbo with bolt ons and FMIC.
Alot of KAs guys are cheap and wont spend money on reliable stuff like ecu tunes or upgraded fuel pumps. (retarded base timing, stock fuel pump....etc)
Ive even seen KA guys complain about headgaskets costing too much. I'd spend 150 bucks for a high quality KA headgasket if they made one. SRs head gaskets start from 150 bucks and up.
In the end, spend your money right and either engine will be fast.
Modified by sunnys14 at 10:42 PM 8/7/2008
A KA can rev higher with supporting modifications also, just a little more than a SR.
You better not say that to its face.nissanfanatic wrote:No, its a design flaw by physics.
I understand that. the fact is that the ka can out perform the sr with out reving high. it has more stroke and displacement than than the sr. to me if you want a "beter" motor swap in a rb25. I have seen plenty of blown sr's as well. I have a built ka getting ready to go in soon with pauter rods wisco pistons and all new timing conponents for the same money that i would have spent on a used sr.480sx wrote:He was talking about rev capability, and the ability to benefit from higher rpms.
Its more than just the long stroke, the crank was not designed for high rpm operation. At over 5500-6000 rpms crank vibrations start leeching your power as you can see on most any ka dyno. As you climb up the RPM range it becomes exponentially worse. These vibrations will also eat your bearings alive given time.
FCW crank and billet rods(and o/c the headwork..) for a high reving Ka, but at that point, you really might as well just choose a different motor.
because the ka is better you proved it your selfnissanfanatic wrote:
And I do dislike most modern engines. I am considering buyingfor a daily driver. an S2000 I honestly do not understand why I keep messing with the KA. It is the exact opposite of what I see as optimal in all regards to design with the exception of structural integrity and cam over bucket valvetrain design. An S2000 would be much closer to what I would consider as a good design.
Just use your imagination a little bit and they will look the way you want them toGTR PrYdE wrote:p.s. why is that without nipple, it's totally safe and not for legal for all??
You can show the whole boob, just not the nipple! lol
sr parts are more expensive than ka parts and in the end the ka has more displacement than the sr which = more power for the moneyall4sho wrote:not true on the parts for a sr you can get alot more than you think over here.
