95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Wed Nov 22, 2006 3:55 pm
this is the list of things that i found that i have to check untill now:
1) vacuum lines, places where they connect, the problem here is that there are too many (7-10) that i didnt find places for, so i just sealed them, although that might not work with all of them, some need to go somewhere for the engine to work correctly, i need to know the crutial vacuum lines for the engine to work right, a list of them is much appreciated
2) checking the fuel injectors with a multimeter, what voltage and wattage should i look for (numbers)
3) check spark plug signal, again voltage and wattage is what i dont know
4) pcv valves, how to get to them and inspect them
5) engine oil is slightly leaking from the present oil filter (fabricated to fit), got an oil filter relocation kit but with the wrong thread (needs to be rethreaded) to fit, working on that
6) connecting the boost controller, where should it be tapped to (not a priority yet)
7) fule temp sensor, the plug is missing, i have to work that out
8) i filled up the coolant reservoir and the rad, and once i started the car, it overheated, so i shut it down and checked the levels, they were both ampty, the reservoir for sure, but the rad not sure, there was nothing when i opened the the rad ( guessing that it needs more coolant added to fill the engine lines too, otherwise i will have a major issue), the engine lines didnt have a drop of coolant when i installed it
9) adjusting throttle, i heard that it is also possible to adjust from the air idle valve, is that true?, the only why i can keep the engine running (shaking also) is to adjust the throttle to about 1100 rpm
10) cleaning all coil and injector connections, (the injectors had a green powder on the inside of the wire connections, spark plug connections are clean though, but will clean them again anyway)
any advice on the above would really be helpful
