Im running a KA24DE-T i just rebuild this engine so i know its good. For fuel management im runnning megasquirt I V3 fuel only. Right now i have the car running and driving. It drives rough and hesistates and what not. I know it still needs tuning and stuff. Im following along Zig's (
zerothread/279228) setup somewhat. Its got me at a good start cause the car runs and drives but not perfect. I would like for you all to look at my setup and see if everything seems fine.
For anyone whos following along with this post i'v put 500 miles on the new engine and made around 100 datalogs. Im only using a narrowband sensor tuning with MSTweak3000. Its got me a pretty good base tune while im not boosting, but now that im boosting i'v richened my whole map by 40% so that i will not be lean in any areas. Now i just have to retune my fuel map so its more fuel econimical. Later on im gonna get a wideband so i can get my map dead on where i want it.
A few pics for you guys to see what it looks like
KA24DE-TMegasquirt I V3 (fuel only) MSNS-E v029550cc rx7 injectorsrx7 TII s4 turbomodified log t3 manifoldCustom DownpipeNarrowband O2 Sensor (going to get a wideband later)hks wastgate (i think, check pic below to identify)rx7 stock bovno brand intercoolercustom pipingrunning about 8psi timing set to 18 degrees for 8psi of boost.
For Ecu
I can't remember if this is how i excatly wiried megasquirt up, but i will check it on sometime to make sure its correct.
i have stock ecu controlling timing with megasquirt controlling fuel only. You can see in the picture how i wired things up. The big red X are cuts. Because electricity follows the path of least resistance These wire have to be cut b/c it will not supply both the stock ecu and piggy with a signal, you will get bad readings.
For pipingI have stock maf plumbed as a pull type before the turbo and the bov plumbed right b4 the throttle bodie vent to atm. Im not sure if this is correct so any opinions on this would be great. So far im not really having any trouble with this but then again im not hitting any boost b/c im still under my 500 mile breakin period + i still need to tune my fuel map.
For Timing I must retard the timing some because im running a fuel only setup.Based on what boznuttz said timing should be set at 18 Degrees for 8 psi of boost.
This is all i can think of for now.
Modified by Rhapsody at 10:11 AM 3/29/2008
Modified by Rhapsody at 12:48 PM 3/30/2008
Modified by Rhapsody at 12:54 PM 3/30/2008
Modified by Rhapsody at 6:08 PM 3/30/2008
Modified by Rhapsody at 6:17 PM 3/30/2008
Modified by Rhapsody at 7:04 AM 3/31/2008
Modified by Rhapsody at 7:13 PM 3/31/2008
Modified by Rhapsody at 7:17 PM 3/31/2008
