Oh and on a side note b/c im only boosting 8psi right now + i don't wanna have to tune fuel + Ignition so im doing megasquirt as a piggy. I mean everything works great right now execpt i cant really floor the gas. I have to be more smoother with the gas. I wonder if its just cause i'v never had a turbo car b4 or if cause i really need someone who know megasquirt to help me work the kinks out.
480sx wrote:Well im not really that familiar with MS1 but i know that its possible(and thought it was standard for all the MS's..). Check your MS unit itself to see if there is a hole in the case with a spot for a vac line first.
If not you can buy a GM 3.5 bar map sensor and wire it up to the MS unit. You have to do your own research on this though, i simply dont know enough about ms1 to be able to help you out.
You are on the MSFI forums right? So much great info and intel people there, if your running MS you should have a handle on that forum.
After seeing your edit i just realized something unfortunate for you.. Since your running a stock ECU and using the MS as a piggyback im pretty sure your going to have to keep the Maf. Without the maf plugged in, your ECU will go into limp mode and you wont be able to rev past 2500-3g's.
However, even with the maf plugged in it should only affect timing, since your MS is hard wired into your injectors.. So your stalling issue isnt making much sense to me right now.
You do have a vac line hooked up to your MS?
