My fellow boost-heads, what type of turbo that will best serve your application depends on your needs for performance from your engine. During my 18 years of tinkling on CA series motor (can't believe it's been that long), I have gone through many a tribulation as well as triumphs. And during that stretch was the changing of turbochargers. My complete lack of knowledge cost me a ton of money and a miserable car that lagged terribly. Coupled with standard or inferior tuning made it even worse. It is wise to invest in tuning equipment such as a competent EMS as that is the basis of your whole set-up. Failure to do that and you will experience what I use to experience in the form of blown engines or a complete lag monster.
Big turbochargers look pretty darn impressive, but if they are not closely or perfectly matched to your engine's modifications, then you've literally screwed-up the pooch and you are the pooch
For Darian: I would put nothing more than a GT3071r with billet wheels on that puppy and not exceed a .63 on the compressor side. But before you do that, you must upgrade to an EMS that is extremely user friendly, yet powerful because even with the CA18, there are secrets to tuning these motors to make them appear bigger than they are. If your EMS does not have the capability to keep up with your needs, you've wasted your money, time and possibly have wasted a motor or at least the internals (Just saying).
And lastly
for dash, the CA series motor is my specialty. I can build any motor and probably tune most of them as well, but there will always be someone who tunes a specific motor to a point where enthusiasts of said motor is impressed and probably say one tuner/builder is better than another. I tune for extreme reliability. I build engines for extreme longevity. I have built well over 50 of these motors and not one of them performed the same as another. I have built many customers motors and have yet to have one to come back and cry about me building them a bad motor. I don't compare me nor my work to any builder let alone any tuner, but I do know this, in the United States of America, I probably have built more CA18DETs than most shops combined. And if my knowledge serves me correctly, to date, Overboosted180s CA18DET produced the most HP on this side of the pond and it did not fly apart after producing more than 600+ whp. He has since moved on to an RB26 platform and sold his CA, but if he wanted to push that thing even more, it would've held-up just fine.
The engine in my S13 is nowhere near built to the specs of his with my bottom end being of OEM .020 over pistons, stock rods and well worked head with JUN cams in it. Coupled with a stock intake manifold, custom exhaust manifold, Garrett GT35r dual BB turbocharger, old school HKS 40mm wastegate, 1000cc injectors and an SDS EFI standalone, the car produces a comfortable 536whp while still retaining A/C and P/S. It drives very well off boost and comes onto boost like it means business. The difference in this car is, I tuned it for what I want it to do and not for bragging purposes. I wouldn't sell it just yet because I don't get to enjoy it. It is waaay too much power for the streets of Miami, so I turned down the boost to a modest 18psi and the car is still ridiculous. It's all about the tuning and matching of parts and a little bit of luck because the engine in my B12 sentra is better by a long shot, yet it runs horrible and I don't have the time to figure out why. Better engine, more coin spent, more R & D applied, looks fancier and still runs like crap compared to the cheaper motor. Oh yeah, the sentra has the same GT3582r, but with billet wheels, nearly the same heads, custom plenum, bigger and better bottom end (Pauter and JE 84mm slugs), polished crank and meticulous machine work, ring fitment, etc, etc. , but again, it's still not better. Hope this helps some in making informed decisions. I may not be the best at tuning all engines in the U.S. , but I do know what I'm doing when it comes to this one and I treat each and every CA18 engine as its own entity
