twistedsymphony »
https://forums.nicoclub.com/twistedsymphony-u62853.html
Thu Jul 03, 2008 8:57 am
Considering that the vibration occurs when in gear and not when in neutral (I'm assuming that while at speed if you're in neutral or have the clutch engaged you don't feel it?) that would say to me that you can completely rule out tires, bushings, mounts, exhausts and the like.
based on stevetodd's description I would say the issue is somewhere between the clutch and the rear axles... meaning transmission, driveshaft, or rear diff.
