Anyone listen to my videos ^^ I'm going in to dealership this morning my car has 59,500 on it. They listened to my ticking noise which I think it's KNOCKING!! I really didn't notice it until I made the videos, you really can't hear much live and in person. The service manager says it's normal piston noise. I know I can be covered as long as I show continuos complaints about the noises(knocking) my engine makes but they still say it is NORMAL! I asked about the tensioner and he mentioned that "THAT" is more common but I also complained about a constant winding noise my a/c compressor makes and he said and I quote "The noises are not going to go away, but if will make you happy I will change your compressor and recharge the whole a/c system with new oil in it and the whole works". But he also said "I won't change both the tensioner AND the compressor"!! As he stated that nothing was wrong with the noises so "Just" to keep me HAPPY he would change one for me only!! Engine is covered 6/70k so I opted for the compressor... I should add that I have monitored my oi level since I first read the posts on oil burning and my car never showed signs of oil burning so that is a big plus!!
But why the KNOCKING I ask???
Also, I'm doing SOME not ALL of my 60K service.... Which would you guys say is MOST important ??
Not doing tire rotation as I recently put a fresh set of stock 19" on ther, oil change will be done, belts are going in as a freeby since I'm getting the compressor, R2C intake is in so no air filter will be needed, new wiper blades on already.
-ATF change or flush?
-coolant flush?
-in-cabin microfilter?
-differential oil?
-radiator cap?
-climate control seat filter?
All these are recommended under the PREMIUM MAINTENANCE schedule!!
If I choose to just do the schedule 1 and 2 maintenance all I need at 60k is Oil change(already going in for this), seat filters, air filter(not needed for me), in-cabin microfilter and the rest is just an INSPECTION of all the above mentioned in the Premium schedule.... So Again what do you recommend I get done from the PREMIUM schedule?? If anything...
