cody_coyer_92Q45 »
https://forums.nicoclub.com/cody-coyer-92q45-u130578.html
Wed Apr 01, 2009 4:21 pm
hey everyone,
before i get to my problem i just want to say im a long time reader of the forums here at nicoclub and from what ive read in the past every problem i have had has been resolved through you generous folks. so thank you so far. NOW, my car went through a 3 ft deep water puddle last friday. my girlfriend was driving, i was in the passenger seat. she got about half way through and got the front end out then the car just died. im in minnesota and its very cold up here that night it was like 3 degree's above zero. anyway, we boosted the car wouldnt start. i left it for a few hours while i was inside drinking, then we boosted it again. we ended up getting a ride home, i just got th car home yesterday. when you turn the key it just clicks like the battery is dead. so i took the starter off, hot wired it to jumper cables and the starter works fine. but i put it back in the car and it acts like its not turning the flywheel, i can hear the bendix coming out of the starter but its not turning the flywheel. ive narrowed it down to the starter. checked the starter relay, thats good. took out the starter and it works good. i think it could possibly be the ignition switch shorting out somewhere in the routing from the connector on the starter to the battery or wherever it goes, i couldnt trace it cuz it went over the top of the transmission. anyway i was talking to my cousin and he said that since the car was at normal temperature when i hit the water puddle and the temp of the water was only three degree's that theres the possibility that the temperature shift could have contracted the motor so much it seized up? that would suck. anyway maybe the starter is working fine but since the engines seized up it wont turn over. it is IN FACT an all alloy motor right? so next it took a impact socket and a breaker bar and tried turning the crankshaft in front of the engine where all the belts are and with all my might i cant turn it. is the 4.5 in a q45 such a weird engine that it doesnt crank the engine when you try to turn the big nut on the crankshaft to see if the engines locked up? im hoping so, i would be pissed if my engines shot, my car is beautiful and i love it. ohh and when i had the starter out it would work fine when i had juice to the ignition switch and the posts on the solenoid. but when its in the car it throws out the bendix but doesnt spin the starter. maybe the ignition switch is shot? i checked the fuse, thats fine, checked the starter relay, thats fine, when i hot wired it the starter worked fine. but when i put it back in the car it does the same s***! what the FU*K i am lost. i need some input, constructive criticism anything. is it possible that the car got soo wet in that puddle that it froze and shorted out everything. when im trying to turn it over theres something smoking and smelling electrical burning when its trying to start. its not coming from the starter but its somewhere down the block on the passenger side of the engine. maybe thats whats up? anyway im gonna take the starter back off in the morning and take it to the shop and run a test on it, i have a reman. waiting for me at napa. im hoping to god himself that i just need a starter and not a whole new motor. where would i find a vh45de in northern minnesota anyway? i cant find one in the junkyard anywhere. anyway, please help me.
