That's cool your CUZ gave you a turbo. By the time you add all supporting mods, you will still be in the neighborhood of $1200-$1800, depending on where and how you get your parts.You can run an FMU with stock injectors, but I don't recommend it with a t3/t4 set up. That will be too much air moving without enough fuel. You'll be lean as hell, blow your engine in no time.chieu wrote:hey, my cousin just gave me a Garrett T3/T4E 60trim, 63ar,.. i wanna do a cheap turbo set up.. planning on using ebay intercooler.. ebay manifold.. i need to know if i can use stock injectors for that turbo until i get some 550cc... injectors... or something bigger.. can i keep the boost really low..
ic is ok from ebay, but iwould suggest that the mani b quality, from experience of course.jgs top mount,peakboost mani, dont go cheap on this.and what else are u gonna do,exhaust? maf? ecu? tune?if i were u i would think about the long haul. what do u want in the end.300hp 400hp,and buy the real deal stuff to acheive this.chieu wrote:hey, my cousin just gave me a Garrett T3/T4E 60trim, 63ar,.. i wanna do a cheap turbo set up.. planning on using ebay intercooler.. ebay manifold.. i need to know if i can use stock injectors for that turbo until i get some 550cc... injectors... or something bigger.. can i keep the boost really low..
