250sx wrote:orion, what do lyou mean by 3grades of stock pistons?
orions brain ->scruffy63 wrote:i thought there only 2 "grader". the flat topped and the cupped.
just out of curiosity, What kind of power gains do you get respectivly from exchanging the pistons? And how safe is it running that high of compression in a stock engine?scruffy63 wrote:thanx for the great info red coupe, that really helps.
the e has 2 different pistons.flat topped ones that had a compression of 9:1 and cupped ones with a compression of 8:6.
in the de the e pistons either make a compression of 11:7 or an 11:1.
to make absolute sure that you have the right clearances.scruffy63 wrote:is this for power or to get the rings to seal properly?
GRRRRRRR....scruffy63 wrote:well 180 to the wheels is really really pushing it but that is the max I can estimate. the compression itself is about 20-30 hp then with intake exhaust headers ecu and maybe upgraded fuel I believe you'll be up around 200hp. but i only have intake exhaust for power.stock hp is 155 , compression 25hp, intake 5hp, exhaust 5hp. 155+25+5+5=190 at the flywheel. this will add up to around 165-175 at the wheels.
if you're rebuilding a DE with E pistons, then you're going from 9.5:1 to 11.1:1.scruffy63 wrote:but i'm going from 8.6-11.1, so wouldn't my guesses be close? also wouldn't boost or nitrous make the engine unreliable?(faster but unreliable)
keep things in perspective. don't expect to run huge amounts of boost/nitrous on a high compression engine and expect it to last very long.scruffy63 wrote:so what about my reliability question?
