No My freind owns this shop. I am sure they wouldnt try to rip me off or nothing. Well they did a Compressioon test then they added oil and did another test. One of the cylinders was low. Well, I blew a headgasket and an Exhaust gasket. The Brian Crower Springs and retainers came in today so we r gonna install them as well. This shop builds motors and makes custom kits and what not. So i am not worried.halnfl wrote:I'm not too sure I'd trust the shop that you took it to. Not to knock them or anything but did they run any tests before they pulled the head? It sound's like they heard you coming and want to bend you over by going ahead and pulling it apart because now if you back out, they'll get their tear down. Either way it goes atleast now you know what your up against. Does the shop do alot of aftermarket, or are they just a mech. shop?
I am not really sure what the exhaust manifold is. Drove the car for no more than two days then its been at the shop ever since. Well here is what happened fellas. The guy i bought the car from told me that the Wastegate Actuator needs a bigger spring to hold the pressure. The boost was spikin a little. It was tuned for 18psi i believe but sometimes when i really go at it i saw 22 and 23 psi. I was running 91 octane. I never had a turboed Car before so i am not all used to this race gas thing, but i am assuming its important. So i think during the race the boost shot up and thats when i blew the gaskets. So is there any difference with the new Brian crower and Retainers i am installing?? The shop told me i might as well put em in and i did.nissanfanatic wrote:What exhaust manifold are you running?
By looking at your numbers, it looks like possibly the exhaust manifold you are running may possibly be restricting exhaust flow in the higher RPM which could be causing excessive heating of the exhaust valves and causing pre-ignition...
What CR is the engine, what boost pressure were you running, and what fuel were you running?
Didnt you say your bottom end was built or something? if you have a built bottom end dont just exchange it for a stock one. Either get them to fix it properly or tell them to give you compensation for them ****ing up.ZUL8R wrote:Its the T6-06 Greddy turbo. Greddy FMIC, big injectors, and 3" manifold and exhaust. Well Here is the news fellas. The shop didnt start the car when they got it. I paid $2100. They told me it was the Valves. So they took the heads off, send them to the shop and told me the problem is fixed. Three weeks later i go there. Start the car for the first time. AND ITS MAKINTHE SAME FREKIN NOISE FROM BEFORE. So now i paid $2000 for no idea what Was pist and they said they would take out the motor see what the problem is and fix it and i wouldnt pay anything. So i am like ok. Now its two weeks later and they said they have another KA motor there that is almost brand new and they wanna slap the bottom end on mine. What shall i do?? Shall i say yes or what shall i do??
lol..what a lame *** shop.ZUL8R wrote:Its the T6-06 Greddy turbo. Greddy FMIC, big injectors, and 3" manifold and exhaust. Well Here is the news fellas. The shop didnt start the car when they got it. I paid $2100. They told me it was the Valves. So they took the heads off, send them to the shop and told me the problem is fixed. Three weeks later i go there. Start the car for the first time. AND ITS MAKINTHE SAME FREKIN NOISE FROM BEFORE. So now i paid $2000 for no idea what Was pist and they said they would take out the motor see what the problem is and fix it and i wouldnt pay anything. So i am like ok. Now its two weeks later and they said they have another KA motor there that is almost brand new and they wanna slap the bottom end on mine. What shall i do?? Shall i say yes or what shall i do??
You say this is a friend of yours? Evidently he values your friendship at less than $2100. So, they pulled the head, did a valve job and replaced the gasket and now you are back to square 1?ZUL8R wrote:Its the T6-06 Greddy turbo. Greddy FMIC, big injectors, and 3" manifold and exhaust. Well Here is the news fellas. The shop didnt start the car when they got it. I paid $2100. They told me it was the Valves. So they took the heads off, send them to the shop and told me the problem is fixed. Three weeks later i go there. Start the car for the first time. AND ITS MAKINTHE SAME FREKIN NOISE FROM BEFORE. So now i paid $2000 for no idea what Was pist and they said they would take out the motor see what the problem is and fix it and i wouldnt pay anything. So i am like ok. Now its two weeks later and they said they have another KA motor there that is almost brand new and they wanna slap the bottom end on mine. What shall i do?? Shall i say yes or what shall i do??
Thanks alot bro, that was really good to hear. Well they are putting a bottom end on the car as we speak. And for the money i spent they did some work but not what i really needed i guess. in the price i paid there was BC valve springs & retainers as well as a greddy waastegate actuator and then all the gaskets. I honestly would have had my whole bottom end built for $2000 right?nissanfanatic wrote:zerothread/226410
Yeah it was the MAF. So now the car needs tuning because the Injectors are dumpin too much fuel and turning the Spark plugs black. But the motor has been put together and its been less than 50 miles. The car cant be put on the DYNO right?? I need answers quick cause they wanna tune it tommorrow. LMK guys. I really do appreciate all the responds so far.chicos240 wrote:Wow, thats one hell of a story....A lot of good lessons learned from reading it. The 2000rpm deal could be your MAF, clean it, check the wiring.
