pig rich s15 sr
lilpiton
Car: 92 hatch
Okay guys, so I fixed one problem and another problem is here.
I got my car to start and everything was good. the only thing is that my check engine light is on, as some of you might know I dont have the OBD port hooked up so I cant really check for codes. But I remember like 6 months back I had a problem with the coolent temp sensor and the car (when warmed up) didnt want to start. Altho it would start when I unhooked the fuel pump and then once it started i could hook it back up and ran fine. So now the same thing happened and I had to do the same thing.
So now that a had done this for about ~ 2 weeks I was driving home and the car started acting really weird, it would bug out back fine stutter and even some of the time I could of drive fine and it would loose all the power (like fuel cut off) at like 4k and them power back up at like 2k :wtf2:. it also has a very hard time to idle, does die out when stoped at a red light, smells like fuel and smokes black smoke.
I checked a different MAF and did the same thing, but I didnt try driving it with the other MAF.
I got a lil video of it ideling (sorry for the quality)
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
2 things. Video isn't on here, and you CAN check codes.. I'll post the link in a sec.
BLAMO! fault-codes-t494878.html
Just reread your post, and it sounds like you have a spark or CAS issue...
Actually, is your fuel pump hardwired? Another thread on here, I pointed out that the fuel pumps tend to not get the voltage they need, and the guy happened to have this issue. He found a wire that was causing it to not only drop at the pump, but at the coils as well. (I have no idea how these 2 are tied together, but it definitely sounds as if they are, and if so, then when you're unplugging your fuel pump, you could be allowing more voltage to go to the coils for your initial start. This is all theory and I haven't looked into it too much, but it KIND OF makes sense.)
yoozef
wouldn't hurt to clean your grounds, i just finished my swap and it had loopy idle and black smoke, best way to check is to grab a piece of wire and touch the intake mani and a bolt on your wheel well, if it clears up, clean your grounds
lilpiton
Car: 92 hatch
so i changed the coolant temp sensor and it made the car run 3 times better but the check engine light comes on sometimes and them that happens it tends to stutter a lil bit and then the rpm dropes to like 300 when coming to a stop.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
knock sensor and clean your maf and throttle body
ciscos13
Car: 89' 240sx hatch, s13 sr
when my car died every time i stoped... it was because my IC piping was loose.
USMCgetsome
vacuum leak can cause this issue as well as maf death. Investigate both
lilpiton
Car: 92 hatch
will be doin a boost leak test tonight and will clean my maf and throttle body
benarovi561
Car: 92 black hatch
which temp sensor did you swictch? the one that is for the ecu or the gauge? i have the same problem u got. and my coolant temp dont work... and the idle s*** is the same for me. whatsup?????
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Have you checked the code cor the CEL? That would be the best place to start.
