Fault Codes
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
ECU FAULT CODES
Long Flash - 0.6 seconds on (the first digit)
Short Flash - 0.3 seconds on (the second digit)
Long Gap - 2.1 seconds off (used between codes)
Short Gap - 0.9 seconds off (used between digits)
There's a screw on the back of your ECU. Turn it counter-clockwise until it stops. Don't keep trying to turn, it won't get any harder and then stop. It'll just stop. Then, turn the ignition key to on. Either your gauge cluster will flash, or the check engine light will flash. Count the long flashes, then the short flashes (only count how many times the light is ON), and you'll have a 2 digit code.
Note: Don't forget to turn the screw clockwise again when you're finished.
Code Meaning
11 - Camshaft Position Sensor
12 - Air Flow Meter
13 - Coolant Temperature Sensor
14 - Vehicle Speed Sensor
21 - Ignition Signal
25 - IACV - AAC Valve
26 - Boost Pressure Sensor
31 - ECM Fault
32 - Exhaust Gas Recirculation System
33 - Front EGO Sensor (O2-1 Sensor)
34 - Knock Sensor
35 - EGR Temperature Sensor
36 - EGR BPT Valve
37 - Closed Loop System
41 - Intake Air Temperature Sensor
43 - Throttle Position Sensor
54 - Signal from Auto Transmission
55 - Other Malfunction. CONSULT Terminal Required
65 - Cylinder 4 Misfire
66 - Cylinder 3 Misfire
67 - Cylinder 2 Misfire
68 - Cylinder 1 Misfire
71 - Random Misfire
72 - TW Catalyst System
76 - Fuel Injection System
77 - Rear EGO Sensor (O2-2)
82 - Crank Position Sensor
84 - Automatic Transmission Diagnostic Comms Line
95 - Crank Position Cog
98 - Coolant Temperature Sensor
103 - Park/Neutral Switch
105 - EGR Solenoid
111 - Inhibitor Switch
112 - Automatic Transmission Speed Sensor
113 - Automatic Transmission 1st Signal
114 - Automatic Transmission 2nd Signal
115 - Automatic Transmission 3rd Signal
116 - Automatic Transmission 4th Signal
118 - Automatic Transmission Shift Solenoid Valve A
121 - Automatic Transmission Shift Solenoid Valve B
123 - Automatic Transmission Overrun Clutch Solenoid Valve
124 - Automatic Transmission TOR Conv Solenoid Valve
125 - Automatic Transmission Line Pressure Solenoid
126 - Automatic Transmission Throttle Position Sensor
127 - Automatic Transmission Engine Speed Signal
128 - Automatic Transmission Fluid Temperature Sensor
(Most of the info on here I got from 240sxmotoring.com. They're a NICO sponsor and their customer service is 5 stars. The info can also be found in the service manual.)
CRyan
Car: 1997 Nissan 240SX
It flashes "55" when everything is good to go too, right?
PyR0NiAk
Definitely not.. Part of me wants to assume you're being sarcastic..
zach-Ka
Car: 1990 240sx (SR)
There is a lot of mal-information out there. I have read several times that 55 was the good to go code. But I trust with all the research you do that this is correct.
O and IDK if this is normal, but my friend black-top with a J4 ecu has no screw... lol
PyR0NiAk
I have NO knowledge about J4 ecus... I'm getting ready to fly, but I'll research it tonight for you. :)
Hijacker
Car: '92 240sx Convertible
'94 F-150
I'm looking in my service manual right now for s13 KAs (Nissan uses the same flash codes in its ECMs for similar generations) and 55 is "No Malfunction in Above Circuits" My S13 JDM FSM unfortunately doesn't have a code list, it only has circuit diagram, ECM pinout, general maintenance, and mechanical. I double checked with my S14 manual, and 55 is "No Malfunction in Above Circuits" according to S14 ECMs as well.
PyR0NiAk
Weird. That's the list from 240sxmotoring. Need someone with a consult and 55 showing up to test it out.
Jdslideordie
here is a question when your ecu is flashing code 55 for you guys is your car not starting too? mine is cranking but not starting..and its flashing code 55 let me know asap thanks
PyR0NiAk
55 simply means (to my understanding, at least) that the ECU can not figure out what exactly is wrong. This means nothing may be wrong, or something else might be wrong. Some people always flash a 55 with their perfect running motor. Some don't flash anything. If your car isn't starting and it's a fresh swap, check to make sure your fuel lines aren't reversed. Otherwise, go with the basics: Fuel, Spark, Compression, and Timing.
