After reassembly:
keep using your cheapo oil (if your car sees garaged starts only) with weekly oil changes with ATF trick.
If you dont see garaged starts use chevron supreme in 5w-30 (walmart 1.14 per qt) which is the cheapest oil thats still good.
Use walmart ST3600 filter ( $2) at each or every other, change.
Dont use kerosene based flushes, as you have too much stuff left in your lower gallerys and it might clog stuff up.
Might consider a envirolution flush spendy but should safely cure your lower oil gallery's that you cant get to by hand.Afterwards you should ahve a clean motor as you got the rest that envorolution doesnt.
Fred..
