pictures of my projects !! enjoy!!!
ca20det
Car: 89 240sx 93 sentra
intercooler mounted
new project winter 2010 :D
intercooler brackets
engine wiring done(front and corner ligths as well)
Idahos13
Car: 93 240sx hatchback
Wow I'm glad I found this build! You have came a long way on this car man! It looks FANTASTIC!!! As for the bike I'm thinking the ca18det should go in there it looks like it would fit ha jk I kid. Good luck with everything!
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
this was SO good.
until that wiring MESS. yikes. find new friends, friends that do clean wiring.
love this build otherwise
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
ca20det wrote:
I'm kinda anal about wiring too. All red wires are gonna be a b***h to go through if there was a problem.
White Comet
Car: fc, s13 and mazda6, Sierra
^ yeah it's fine til something needs wiring attention down the road then you'll hate the color red
Dire91
Car: 1997 Nissan 240sx SE
Man this s*** is awesome I praise guys who do projects like this I've always wondered though, what does a project like this set you back?
sil80_chris
Car: 1991 Nissan 240sx
Dire91 wrote:Man this s*** is awesome I praise guys who do projects like this I've always wondered though, what does a project like this set you back?
He mentioned that it was at 25 grand a couple of pages ago so i'm guessing it's more now...
ca20det
maybe I did not calculate 25G maybe if I count the amount of money I spent on tools but the knowledge I gained from this project is priceless and keep in mind that I built the garage too...
ca20det
this is not a mess we checked the routing of every wire that we extended (in red wire) for continuity and the color or the wire at the plug is still the original color only the extension for the wire that were too short are red the is no way I could have found the same color for all the wires.... so when the wires are all wrapped up with black plastic shield the color from one plug to the other will match....
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
car looking stupid clean. simply superb.
White Comet
ca20det wrote:this is not a mess we checked the routing of every wire that we extended (in red wire) for continuity and the color or the wire at the plug is still the original color only the extension for the wire that were too short are red the is no way I could have found the same color for all the wires.... so when the wires are all wrapped up with black plastic shield the color from one plug to the other will match....
ok but think about this. when trouble shooting any problems in the mass of red wires, you're going to have to undo all the loom and unwrap the whole bundle just to see what each individual wire is for
tunerinms
Car: '93 s13 coupe
This build is epic. Im glad i found a good clean car. I could never do what you have done. AWESOME!
ca20det
no you really do not understand what I'm saying... the red wires are only for wires that needed more length because of the RHD/LHD swap... so in the plug the wire color is the same as it was before.. you will not even see the red wires if you have problems you just have to test the continuity of the wire with a multimeter to make sure that you have the right wire if everytime you have a wiring problem you follow the wire from point A to point B you'll need a trained mouse to follow it through the small holes in the firewall and dash
kgriffin
Car: 95 240sx
keep up the good work nice bike too lol
TomahawkJack
Car: '90 s13 hatch ca18 powa
looooove ittttt!!
ca20det
not much progress, I had a lot to do ... changed program in school, motorcycle courses, work, holidays ...... a few problems though, my injector pintels desintagrated.... so I need new ones or new injectors.... wich means recalibrate the ecu... etc.
samco hoses, looking for a new rad as well, just did not want to spend 30$ on coolant and take the chance the old rad would leak.... so I'm shopping around....
kouki spoiler fit test need to cut it glue a bolt refinish sand prime and paint
maybe worked out my P/S problem with a new fiting and adaptor pressed on the old pressure line just need to see if it leaks when I turn on the engine...
longer nismo stud
project 2010
took the luggage and fender out....
sketch of the final look
parts bike
duffman1278
Car: 89 240sx Hatch, the wildcats!
Did you use flux core to weld SS?!!?!?!
ca20det
nope the same shielding gas I had for welding steel sine I did not have acess to a TIG welder then .... I'm practicing at school on the TIG for future SS an Alu welding needs
Bumnah
Car: 1992 240SX, black. Bone stock.
Nice project. It's not too over the top, so it should turn out great!..The suspension work is worth it's weight in gold!
The240seller
Car: 240sx
lving the project. You just gotta hate canadian winters. Hope she comes out nice. good luck on the bike build
elchoccolatte
Car: 2K3 2.5 SL Altima, 91 Nissan 240 Sx Se
Mad PropZzzz...
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
I actually sat here and looked through every single page.
WOW
A lot of work but it looks like its paying off.
NICE
ca20det
small update
rear suspension, exhaust, bumper and trim ready for inspectiondown on its rear wheels
Windshield installed I need to reroute my cold pipe (and TIG weld it at school) because I did not receive the good one...
engine harness all tested out should work out just fine I still need to wire up my E-fans, the low speed on a thermostatic switch and the high speed on a switch on the dash for drag and drift fun :D
motoman399
Car: 98' wrecked (RHD coming soon) 240
its looking real nice. congrats. by the way, did you ever use that kouki spoiler? is it oem? wanna sell it lol
ca20det
yes a friend of mine is molding it to the trunk for me... its a stock s14 kouki spoiler
motoman399
you should trade me my fiberglass one for yours. fiberglass would mold better and i would love a stock one for my kouki. ill pay shipping both ways!! mine is in good condition too.
ca20det
haha osrry its already in the process !!! and still the friend whose molding it asked me fiirst to exchange for his in fiberglass but since mine was cracked I kept it!
bllabong89
Car: 1995 s14
question, I know that flatblackian asked for some pics of the rotisserie. Would you be able to send me some pics also if you still have them or if it is still together? Also, how much did you spend on the materials for that. I have seen one from northern tool co and its like 900 bucks so i was just thinking of making my own but I havent seen anyone do it until now. Great build by the way :dblthumb: .
ca20det
IIRC it was no more than 200$ its about 2-5$ per foot of tubing you just have to know how to weld
gotta love the kouki two friend of mine have one... you do not seem to need the rotisseri though...
angelscrx
Car: 1992 240sx
I have to admit this is a project of love! There is some serious dedication to this project and I better not ever see a for sale sign on it!!!!!!!!
