GraySilvia »
https://forums.nicoclub.com/graysilvia-u3605.html
Thu Jan 29, 2004 4:30 pm
Well, the wastegate to downpipe tube that they provide that is supposed to be a slip fit was NOWHERE near fitting correctly. So I had to cut and file and hacksaw and huff and puff and get it welded together. This would be the same on the S13, actually, unless I just had a kit that was out of spec for some reason.
Next, the bracket to hold the turbo up that connects the head had a hole that needed to be rounded out to fit properly; not a big deal at all.
The way the piping/underhood is on the S14 means that the hot pipe they supply is too short by a lot, like 4-5". So I had to fab something up.
Also, the intake piping didn't work very well with the S14. The intercooler piping kinda interfered with the air filter. However, I have an S13 intercooler, with the inlet on top of the fender as opposed to the S14 piping which has its inlet on the side. I suspect if you had S14 piping, it would clear just fine.
Really, really minor stuff in actuallity. The rest of the kit came together perfectly. Plugs for the water inlet/outlet on the block, very pretty oil lines. The intake piping seems to be too short, as well. I was having a bad part throttle misfire that turned out to be the MAF too close to the turbo inlet and getting some kinda weird back flow or something. Perhaps the rotation of the flow going into the turbo, i don't know. But, putting the MAF in the coldpipe and making a blow-through setup cured it nicely!
