j43lee wrote:Hi Salem,
Truck looks great! I was wondering, I thought that the Rancho Quicklifts were only made for the front axle and they recommend using the 9000xl with spacers for the rear. Did you have any problems installing the quicklifts in the rear and what was your reasoning behind putting them on all fours?
The "QuickLift" for the rear are the Armada urethane spacers and 9000xl shocks and in hindsight I would've used Old Man Emu rear springs instead of the spacers. The OME springs raise it up 2 1/2" in the rear vs. 1 3/4" for the spacers, which the front is raised 2 1/2". So, I have to keep air in my rear bags to level it out. The whole lift was easy to install except the front coils were a pain to compress, they are heavy mofo's.
iPath wrote:Honestly I think this stigma that "you can only have a lift if you rock crawl (beat the s*** out of your vehicle)" is plain dumb, if you do anything outdoors where a little extra clearance and larger tires gives you a slight upper hand I would think it's acceptable. Let people do what they want and stop acting like elitist pricks.
Thank you...
mfoofat wrote:How much lift did you get? and does your steering wobble at high speed? did you use ring centric?
where did get your lift do you any problem with aliment?
no ring centric, just lug centric. I don't have any problems, I just torque them in the air. And the alignment is set to factory spec with no problem.
