ALIGT4 wrote:I'm looking at putting on some 20" aftermarket wheels but I don't want to lower it as its my dd and i drive about 3500 miles a month.
anyone have pics of an 37 or 56 rwd? Mine is an m35h so i assume it would be similar in height as opposed to the x. I've searched quite a bit but haven't had much luck. I just don't want too much of a gap....maybe some other tire options?
Welcome!
Unfortunately I don't quite understand what pictures you are after. Do you mean a RWD M with 20's and not lowered?
If you don't plan on lowering the car I would run a set of OEM Infiniti 20's. If you really want aftermarket wheels go with something with a full face. I would definitely stay away from anything with a deep dish and/or lip. This wheel design seems to accentuate the excessive OEM wheel gap.
Also the only way to not have
too much of a gap is to lower the car. Even with 20's your overall tires diameter will be the same as with the 18's, so the gap will not increase or decrease. You could run a larger tire but it will affect your speedometer readings and may rub on the body. Basically you don't want to do it.
Based on the little I know OEM 20's are my suggestion.
