There, fixed it for ya!pandapants wrote:205/45 on a 9" wheel is dumb. It has less clearance than 225/40.
or 285asoomal wrote:You mean a 275 right?
Chinese mustang wheels. I got a set of FR500 replicas. His are probably 17x10.5 rears like mine.180sxblack wrote:^ what rims are those in the back?
HoosierSX wrote:fcking retarded
but anyway, this is a 215/40-17 on a 17x9
this looks perfect in my opinion
and here is your 205/40-17 on a 17x9
doesnt look very safe at all
Modified by HoosierSX at 5:57 PM 10/27/2009
im not the only one that thinks thisblacktop sr20kid wrote:how is that dumb??205/45 isnt that much of a sretch?
im running a 215/40/17 on the front right now and it's not stretched enough at all!!!
Hard to turn down a $460 set of wheels with perfect offsets and huge width.
You're stretching for clearance, correct? 205/45 will indeed give you LESS clearance than your 215/40 and even 225/40.blacktop sr20kid wrote:how is that dumb??205/45 isnt that much of a sretch?
that happened because of sidewall damage caused by the tire going flat, NOT because it was stretchedHoosierSX wrote:
Modified by HoosierSX at 2:38 PM 10/29/2009
Are you runnin a 245 in the rear?pandapants wrote:
205/40 on 9.5 up front
205/45 is dumb. It has less clearance than 225/40.
So basically you're saying that when I'm going down the freeway at 80mph and my tire blows out that this is what's going to happen?ashibah83 wrote:
Yes, no matter the tire size.ddgsxr504 wrote:So basically you're saying that when I'm going down the freeway at 80mph and my tire blows out that this is what's going to happen?
It's more for well clearance.Not everyone can tub the wells. Trying to keep the Diameter as small as possible gives better clearance.ddgsxr504 wrote:Also a 205 on a 9" is only 8" of tread width, why buy a 9 inch wheel only to put an 8" wide tire? You want clearance??? Roll your fenders and or pull them. Modified by ddgsxr504 at 7:47 PM 10/29/2009
225/45Not mine either.n240sxfnatic wrote:Are you runnin a 245 in the rear?
hmm thats interesting. i dont rub with 205/45 that i got for cheap so ill probably switch to a 225/40 later on. good to know. thank youpandapants wrote:
No reason for stretch at that ride height.Shayl wrote:Haters.
205/45 on a 9.5
I hope that car has airbag suspension or something cuz there was absolutely no need to stretch that poor tyre.Shayl wrote:Haters.
205/45 on a 9.5
