Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Feb 11, 2006 6:26 am
The oem factory thermostat is speced at 194F 100% open.IF THE TEMP rises to 195F the ecu starts decreasing ignition advance! To decrease power output................this can lead to thermal runaway once the ecu has reduced advance by 5 degrees: [195F>200F>205F>210F >215F]
The design temperature is supposed to be no less than 174F and not to exceed 194F.
People get confused at the above since the theromstat MUST BE Partially closed to regulate.
Themostats on Q fail from the rubber seal failing, allowing too much flow that the closing of thermostat cannot control.
Failure to reach 174F means the thermostat MUST BE REPLACED.
Many shops leave cars out overnight vs Nissan assumption that in the shop they will be started at 60F..........thus short Consult time lockout [10 minutes] which should actually require only 5 minutes to warm up a 60F coolant Q.
I would say half the Q I test won't warm up to 174F in winter.........they get close [meaning thermostat is worn] and still should be replaced.
Aged O2 take longer and longer to become sensitive and allow closed loop control to drop out fast as soon as the speed drops to idle.
AS new requires new parts frequently, some like thermostat every 30k and O2 every 60-100k.
OBVIOUSLY cylinders 1,2, and 3 need attention = BG 44k and or a BG Concentrate rail flush.
I have a trick which shows if a rail flush will help: Use non biting pliers to close off fuel return rubber line in repeated but very short [ a second closed then wait 3 and repeat 10-15 times to raise rail pressure from 34psi to 60-70 psi to force trash thru the injector screens ----- fleck off carbon/deposits from injector tip..............does power balance ratios change? It should get temporarily better.
Usually helps without doing much fuel pump damage [pump has it's own blow off high pressure valve]. Afterall the pressure rises to 43.4 psi under acceleration.
