Performed Nissan Consult and Power Balance Test Today
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Q451990 wrote:I seem to recall someone saying that Sears will calibrate them if you happen to have a Craftsman wrench... I haven't confirmed this though...
Heath
Well they didn't mine, they just gave me a new one. All those guys are dead anyway it was so long ago.
I moved on to SnapOn.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Q45tech wrote:I have a trick which shows if a rail flush will help: Use non biting pliers to close off fuel return rubber line in repeated but very short [ a second closed then wait 3 and repeat 10-15 times to raise rail pressure from 34psi to 60-70 psi to force trash thru the injector screens ----- fleck off carbon/deposits from injector tip..............does power balance ratios change? It should get temporarily better.
Usually helps without doing much fuel pump damage [pump has it's own blow off high pressure valve]. After all the pressure rises to 43.4 psi under acceleration.
Is the fuel system (rubber fuel lines and injectors) designed for that amount of pressure?
Why would the problem temporally go away? I would think that if they were clogged and this unclogs the injectors=problem solved.
I will try this since my fuel pump is already on its way out and yes I have another well a couple other FPCU's.
Q451990
Wow... let no one ever tell Paul that he needs to search. Three year old thread revival
Heath
