Where did u get that rear end from and how much?? does it have the correct abs sensors and companion flange?Jeff Williams wrote:The Mad Max ECU won't help you off the line. At least the tune I have won't do it.
The 90-93 transmission might help. I am building one for Lola right now.
The Billet TC will do a great deal towards making the car quicker off the line. Lola will get one of these with the new transmission.
The 4.08 rear will do it as well, but you will loose some top-end (if you ever use it). I have a 4.11 sitting on the garage floor waiting to go in her once I have the transmission in and have done a few passes first.
Did you ever post up a time slip to compare to Robs?elwesso wrote:Ive driven robs car (4.08 with stockish TC) and my car (stock rear with high stall TC). I like the high stall TC's better.
I was just messing with you.elwesso wrote:im saying from off the line performance, plus you have an unfair advantage with the headers.
Dennis - the before and after dyno sheets show an increase in TQ ~4k.Q45tech wrote:Why would aftermaket or homemade headers help and not hurt the below 4,000 rpm performance.
Until the back pressure [per unit of time] starts to create inversion nothing is to be gained.
Engineers design for peak torque at some reasonable rpm and then deal with HP.
Design fundementals are pretty obvious when published torque exceeds published HP in English units.
When you see the converse: higher HP than torque you know they are creating numbers for magazine sales......................my horsey organ is bigger than yours.
I think some Q have the ABS rings on both sides of the shafts too. Hicas, Traction control, or active suspension one of those options required for infiniti to put the abs rings on the shafts. Or maybe it was a mid year update. I remember hearing about it.NOR*CAL 916 wrote:ia have the r32 skyline gt-r diff, its bolt on and its a 4.11 gear ratio not to mention its a clutch type lsd. i cant get the asb to work since skylines have the abs rings both sides of the shafts while the q has it at the companion flange. driving improved overall city and highway. i can now smash the gas pedal from a stand still and leave two roasting lines in the asphalt, the stock 3.53 gears would NEVER do that. i can get one for you for $500 plus shipping, let me know if your interested.
With that sensor not working, I think the ABS system will disable itself. What you could do is short the rear sensor and this will allow ur front brakes to have abs. The front brakes do all the work anyway.
Not so. While the front brakes do indeed do most of the braking, better to lock up the front wheels than the rear. That's why when pickups first came out with ABS, it was on the rear only. Blow a rear tire at speed, or lose the rear end in a powerslide and you'll quickly see how this works.Clyons0203 wrote:
I'm not sure if the statement that the lsd is a clutch type is correct. I found one for sale that claims to be from a r32 gtr but it has a sticker that states viscous lsd on it. I do not race my Q but I do find that it is missing some off the line snap for my taste.NOR*CAL 916 wrote:ia have the r32 skyline gt-r diff, its bolt on and its a 4.11 gear ratio not to mention its a clutch type lsd. i cant get the asb to work since skylines have the abs rings both sides of the shafts while the q has it at the companion flange. driving improved overall city and highway. i can now smash the gas pedal from a stand still and leave two roasting lines in the asphalt, the stock 3.53 gears would NEVER do that. i can get one for you for $500 plus shipping, let me know if your interested.
